Question about Bosch 24 in. SGV53E03 Built-In Dishwasher
Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
My parents new dishwasher seems to be stuck on a cycle. It's only 2weeks old, and has worked perfectly up until now...the drainage pump is on constantly, even where the washer has been put into the reset mode. We have checked all the filters and tried filling the washer up manually so it has something to drain when switched on! The water drained fine, the cycle ends but the drainage pump is still running...HELP...!!!
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
    Sergeant:
  • 225 Answers
As the machine is only two weeks old I would go straight back to the seller and report the fault to them - and take a copy in writing. Don't be fobbed off with any instructions to get in touch with the makers - your contract is with the seller and it is up to them to fix it! And if you mention compensation for the inconvenience caused by this defective product, it might help speed things up.
Hope this helps! D.
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Feb 08, 2010 | Bosch SHU4006 Dishwasher
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
Dec 28, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SGV53E03 Built-In Dishwasher Logo
571 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
