Question about Samsung NV3 Digital Camera
Nv3 turns off when i try to use the camera
I woke up 1 morning to discover that if i try to use the camera it turns of as if the battery is low.other functions like the mp3 are working,i can even view the pictures but if i try to use the camera the shutter opens and closes and the camera goes off.also does anyone know a site i can download the converter for converting videos to pmp format?
  • 4 more comments
  • kathleentayl Jul 27, 2008
    When the camera is switched on it stays on for only a second then switches off again. The camera is fully charged and I can view pictures already taken. Have checked that the charger is working and also tried to charge from usb port on computer.
  • Anonymous Nov 09, 2008
    I has the same problem. When I turned it on a message to "turn the camera off" came and the camera was gone... The slap worked fine! I think the lens cover was stuck...
  • frizz-face Feb 06, 2009
    When I turn my on to use the camera, It come up with the message Turn Off Then ON Again. It works fine with the MP3 though :(
  • Anonymous Mar 20, 2009
    heheheheh, i cant believe it, i had the same problem and solved by slaping it. unbelievable
  • Anonymous Apr 20, 2009
    nv3 turns off when i try to use the camera
  • spsjr1987 May 13, 2009
    Holy ****! I thought i was gunna be out $300 bux but the slap thing really worked!!! hahaha awesome...but kinda strange that samsung would have this problem hehe.
Thanks MAN Your Slap things Worked man, I slaped My Camera twice and the camera fixed im so happy
Posted on Aug 24, 2008
I created the problem and i have solved it
Posted on Aug 22, 2008
  • cokane Aug 22, 2008
    as you turn on the camera slap it real hard and it would be its old self again
Flippin Wicked !!! Didnt believe this would work but was so hacked off thought i would give it a go!!THE SLAP REALLY WORKS!!
Posted on Mar 22, 2009
How to know battery power in nv3 camera
When the camera is switched on, the battery condition is displayed on the LCD monitor. There is a little battery, with 3, 2, 1 or no bars in it, indicating Full; 3 bars, Low capacity; two bars, one bar and none bar. In all three cases, you should be prepared to recharge the battery. But if really there are no bars, don't shoot pictures anymore,
Recharge or place a spare battery, if you do have one (or more)
Jan 18, 2014 | Cameras
When I turn my camera on, it says to turn off and on again.
dear sir,
the first suspect is your battery,ahich is running in low battery....kindly recharge the battery for few hours and then put your camera on........
next,the problem is usually caused by virus and sometimes it might be software failure also, which causes some of the menu not to function,the only solution is to flash ur cam software from the nearest samsung service centre
thank you.....take care................
Oct 04, 2010 | Samsung NV3 Digital Camera
Camera turns itself off
or this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 SAMSUNG
Hope this will help
Thanks
Byron
Sep 25, 2009 | Samsung NV3 Digital Camera
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
Samsung NV3 wont turn on
take out an reinsert the battery...that works always for me.
Dec 18, 2008 | Samsung NV3 Digital Camera
The Samsung NV3
Well the soloution for this easy problem is just throw that camera away and go buy another one
Sep 25, 2008 | Samsung NV3 Digital Camera
Samsung NV3 Camera
Hey Rider18,
I would try taking the battery out and waiting a minute or two and then reinserting the battery. If this doesn't work I would have it looked at by an authorized service technician, or you could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 21, 2008 | Samsung NV3 Digital Camera
Samsung nv3 sd 'card error ! ' message
my camera say card error, can u help?
Apr 04, 2008 | Samsung NV3 Digital Camera
SD Card Wont Work
Check if the SD card is iserted properly into the camera, eventually pull it out and push it back inside the camera. Also remove camera batteries , repeat the operation, and put back batteries.
If the card still does not work test the card into a different device, it is not unfrequent that an SD card comes defective from factory. In this case take the card back to the retailer and a have it changed.
If the card works on a different device, then it may be that the NV3 does not support 4 GB , there is no mention about max SD format supported in camera specs, or in the manual. In this case I suggest testing a 1 or 2 Gb card at the shop, and then buying right one.
Regards
Apr 02, 2008 | Samsung NV3 Digital Camera
Won't charge!!
Hey ppl, my camera has just doen the same, it wont charge although it works completely fine in all other cases. Ive had it just over a year. Has anyone tried using a new cable? Or is it defintely the camera thats the problem? Either was a simple solution is to buy a charger for the battery itself, one thats independant of the camera. Its not as convienient, as you need to remove the battery and place it in a stand to charge, but it does solve the problem :-D They cost about £10.
Peter
Aug 03, 2007 | Samsung NV3 Digital Camera
Samsung NV3 Digital Camera Logo
190 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
