Question about Nikon Coolpix 775 Digital Camera
My nikon 775 just won't start even after i put in a new battery (i thought it was a battery problem). any clues on what i should do before i retire if permanently?
  • Anonymous Jan 14, 2011
    i checked the battery and it's working (lit up and blew out the tiny bulb). will try cleaning the battery compartment. thanks.
    Scholar:
  • 81 Answers
Hi
The Nikon Coolpix 775 can be powered using a EN-EL1 rechargeable battery or a disposable 2CR5 type battery (Panasonic, Duracell, Maxell etc). If you are trying to use an EN-EL1 you may want to try using a 2CR5 - this would prove if the battery charger you are using to charge the EN-EL1 battery is working correctly.
You can also try and check if the contacts inside the battery compartment are clean - the camera is quite old and there will normally be some dirt deposits after that length of time.
Hope this helps.
David
Posted on Jan 13, 2011
SOURCE:
Nikon coolpix says "battery exhausted" and now won't turn on. I just got this camera not even a year ago
Try using a cloth with alcohol and wipe battery terminals and insert a new battery may help give us a clue to go to another step.
thnks
Jun 26, 2013 | Nikon COOLPIX S5100 Digital Camera
Nikon S8100 digital camera won't power on even with new battery.
1_ recharge the batteries or replace
2) clean the contacts batteries with contacts cleaner very well with carefully
3) see if the battery is loaded in WRON direction
4) memor card slot/battery cover is open.
5)poor contact between camera and battery terminal adjust the contacts and clean.
God bless you
Jul 31, 2012 | Nikon S8100 Digital Camera
Nikon coolpix S8100 won't power on even with new battery.
10 replace batteries or recharged very well the batteries.
2) clean very well the contacts batteries from oxide, dust, dirty. or corrosion
3) batteries loaded in WRON direction
4) batteries is NOT the right type
5) poor contact between battery and cover , clean and adjust it .
6) Memory card slot/battery covert is open
God bless you
Jul 31, 2012 | Nikon Coolpix S8100 Gold Digital Camera...
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
I have a Nikon coolpix 775 and it will not turn on. Please help
Are you still using the original battery.
My first battery lasted 5 years, could be time for a new battery, check out ebay they are available for not a lot of money.
Regards
Matt4666
Jan 11, 2009 | Nikon Coolpix 775 Digital Camera
1997 stratus starting problems
This could the problem with battery getting drain even if your car is parked , this could the problem in the wiring or the grounding in the car ,first check if any lights or the cd player has the power even if the car is parked ............................
Good luck...
Nov 17, 2008 | 1997 Dodge Stratus
Nikon coolpix 775 digital camera
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Dec 02, 2007 | Nikon Coolpix 775 Digital Camera
Coolpix 775 camera does not shut off. Probably the shut off button is not operating
This could be a main-board problem The fact the lens operates indicated that mechanism is OK So what to do- Check Nikon support - will it be repaired at reasonable cost or will you simply bin it- who knows
Aug 12, 2007 | Nikon Coolpix 775 Digital Camera
Nikon Coolpix 775 Digital Camera Logo
71 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
