Question about Onkyo Audio Players & Recorders
My cd player (model dx-1800) is jammed. When I push eject I can hear the necanism but tray will not open
  • 1,512 Answers
Hi djhartness
It will have a faulty load belt to the tray assembly. Not hard to replace if this in an Onkyo DX1800. You need to use a belt the same cross section as the one that has failed. If you need any help sourcing the part, just let me know. cheers
regards
robotek
Posted on Jul 14, 2008
Where is eject button cd is stuck making a grinding noise
On every CD/DVD/BluRay player there should be a VERY small pin-hole on the front of the actual tray(you may have to wipe any dust off the front in order to see the hole). If you stick a saftey pin in there you will release the lock on the tray and it will pop open. Now if the CD is really really jammed and the pinhole trick doesn't work you will have to take the drive apart to get the CD out.
I hope this helps! If not, please comment back and let us know!
Jan 05, 2011 | Dell Computers & Internet
HOW DO i GET CD TO EJECT? WHAT DO I HIT?
There is an eject button on the drive tray, when the notebook is powered up then press this button to open the tray.
If it still does not open then straighten a paper clip and insert it into the pin hole in the tray and push it in gently until the tray pop out, you can then pull the tray fully out to get at the CD.
Dec 10, 2010 | Dell Studio 15 Laptop
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
C D Player Model Sl HD81 will not open / close
Alotta of the times if you have an sd card inserted take it out then repower up the dz 1200 and wallah your eject button is rollin!
Nov 23, 2008 | Technics SL-DZ1200 CD Player
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
DVD player not opening / ejecting
I have the same problem. I just want the damned thing to return my precious audio CD. I can hear a motor trying to open the tray, but something seems to be mechanically jammed.
Jan 17, 2008 | Televison & Video
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Need help! DVD tray won't open
soundsa as though there is a draw drive problem and that could be a motor or as simple as a belt?? are you sure tjhat the eject button works properly as I found out on these denons that the eject switch or push button wont make contact with the switch behind it because the Printed cuircut board shifted??
Apr 02, 2006 | Denon DVM-1800 DVD Player
188 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
