Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1200xl breaks up after itgets hot
1200 xl breaks up after it gets hot
  • soonersrock Oct 11, 2008
    i have an 05 1200xlc, recently it seems the bike starts up great, sounds good and has good throttle response until it gets warmed up,or hot whatever. at this point a slight roll of the throttle it will backfire,pop through the carb, sometimes smoke comes thru the air filter. now if i hold throttle at like half way open sometimes it will get thru that. and as long as i let the cluch out slowly,with throttle still 1/2 open i'll be down the road, until i have to start out again. again if i let sit awhile it will start and it's the same thing. what's up
  • 27 Answers
Sorry mate, what do you mean by breaks up? Could you explain a bit further? Cheers.
Posted on Jul 17, 2008
Replaced rearbrake press switch,now i dont have rear brakes,2004 harley davidson sportster 1200xl
if all you replaced was the switch.. back it out a couple turns and make sure it isn't blocking the port. I've seen aftermarket come with a longer thread that blocks ports. pedal should be stiff if blocked.
if the pedal is free than it must have gotten a gulp of air. sometimes takes forever to get it to moved
May 07, 2014 | 2005 Harley Davidson XL 1200 C Sportster...
What is the stock rake on a 2001 1200xl custom sportster
Hi Anonymous, please be aware that this question has already been asked and answered. Thank you
Nov 28, 2013 | 2001 Harley Davidson XL 1200 C Sportster...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
How to drain engine crankcase oil 2004 1200 sportster
Run the bike to get it to normal operating temperature. Put an thin oil pan on the ground under the center of the engine. Look for the little rubber hose coming from the bottom of the bike with a plastic plug in it and held in the hose with a clamp. Loosen the clamp and save to reuse if it is the screw type. Then pull the plug out and open up the oil fill cap on right side by the seat.
Jul 04, 2012 | 2004 Harley Davidson XL 1200 C Sportster...
What oil do i use for a 99 1200xl sportster
You can use one or the other. If you use regular oil, Harley 20w50 goes in the oil tank and Formula + goes in the primary. If you use synthetic (Harley Syn 3) the same oil goes in both oil tank and primary.
May 29, 2012 | 2006 Harley Davidson XL 1200 C Sportster...
Fuel leaking
sounds like the float is stuck open
Mar 27, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
Bike is not getting any fuel to stay running
fuel inj. when you turn the key on you should hear the fuel pump turn on and pressurize the system for 4 sec. if not check fuse
Dec 20, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
What is the correct motor oil to use for the 1200Xl
20w50 for most regions, 15w 40 for cooler regions.
Be sure to replace the filter at the same time.
hope this is of some help
Ed
Apr 22, 2009 | 2004 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
