Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Blows room temperature air
Looks like everything is ok except this machine only blows room temperature air
  • Anonymous Nov 30, 2008
    I checked all items listed in the previous posting - unit continues to blow room temperature air. Can the unit be recharged?
  • Anonymous Mar 28, 2009
    1 yr old pac l90 blows room temperature air compressure is working evap coil is not getting cold
  • 750 Answers
Welcome to fixya.
I'm Huuum and happy to assist you
The air conditioning
unit works, but does
not cool the room
• window open
• there are heat sources in the room (burner,
lamp, etc)
• the exhaust hose is detached
• air filters clogged
• Inadequate size of the room (too large)
• close the window
• eliminate the heat source
• connect the exhaust hose
• clean or replace the filters
If all this dose not remedy the problem then you need to see service!
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
2006 Honda odessey air condition going from blowing cold to just room temp air
Does it start off blowing cold then goes to room temperature, or was it cold and now any time you turn it on its room temperature
Dec 14, 2014 | 2006 Honda Odyssey
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
7.5 tas high airend temperature
1. Check your oil level, top up, or totally replace it
2. Check your cooler (Radiator looking thing) blow it out with a blow gun
3. Check your thermo valve (may need replacing)
4. Is the room that your compressor is in very warm, ambient air is a big factor in the running of your compressor
5. Do you have all the panels fitted to the machine? These are needed to aid airflow past your air-end
These are the main causes of high air end temperature. It may just need a good service
Hope this helps
Aug 29, 2012 | Ingersoll Rand Rotary Screw Compressor ...
This is a wall unit and it works, but it does not blow cool air it blows air like a fan. That is the only issue I detect. sounds fine.
Make sure that the temperature SP is low so that the compressor should run. If everything that should work appears to be working except for the actual cooling part, then perhaps you had a refrigerant leak. Could you open up the unit and check the refrigerant pipe connections to see if there's anything that look like corrosion.
Jul 19, 2011 | Fedders A1A10W2B Air Conditioner
Cant get the heater to work
Try putting the temperature setting at the temperature that you actually want the room to be instead of a crazy temperature
Apr 22, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Cooling issues (low refridgerant?)
Make sure both the evaporator and condensor coils are clean. After the unit has been off for a couple of hours, start it back up and measure the temperature difference between the air entering into the unit (room air temperature) and the air blowing out of the unit and into your room. You should have approx 20 deg......take this measurement after approx 5 minutes of run time. If the temperature difference less than 15, you may very well have a refrigeration problem. If it is approx 20 degrees, then it could be a dirty coil or an electrical problem.......inspect all of your electrical wires and controls for any signs of overheating.....tighten all connections.
I hope you find this to be very helpful in your diagnosis. :-)
Mar 23, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
397 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
