Question about Hoover S3630 WindTunnel Bagged Canister Vacuum
Does not turn on motor, No power to the Hoover. Cord fully extended and will not rewind.
How to open up the machine at the bottom so to access the cord to repair the damaged connection? Please show steps or figures where to start, Thanks.
Bob
  • Anonymous Aug 28, 2008
    Our S3630 Canister Vacuum will not rewind the cord. Pulling the cover off the machine, I see the windup spring is broken. How do I get a replacement and how do I get the spring replaced?
    Thanks!
    W. Olson olsonw450@aol.com
Solved. I downloaded the exposed view of the Hoover and located the screws.
Posted on Jul 14, 2008
Broken wire reconnected and power was restored.
Hoover has no power. Is there a reset button?
Important Notice Regarding Hoover WindTunnel Series REWIND Bagless Upright... I found some interesting reading here that could pertain to you. Thank you and leave feedback for I am new at this. James please have a great day!
Jul 14, 2016 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I replace cord rewinder on Hoover UH70120?
You should not try this on your own. Take it to an authorized Hoover warranty repair center near you. This is not an easy job and is usually not worth the expense if the machine is out of warranty anyway. If it's within the warranty period, warranty will cover it. My shop is a Hoover warranty center and we have replaced a lot of these.
Dec 17, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
How do I install Hoover part 41911014
Hi Jeffrey, we actually recommend having an authorized service center replace the cord reel assembly on your vacuum. Please follow the link below to locate the nearest service center location to you. Thanks!
Service Center Locator
Aug 19, 2014 | Hoover S3630 WindTunnel Bagged Canister...
Power cord will not come out
There is probably a crossed cord in the rewinder. I am not sure but if you can get into the rewinder you can free up the cord it should go, hope this helps. Chris
Feb 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
Only a month old and it won't turn on anymore
Check Hoover's site to see if your's is under there recall. There's a problem in the cord rewinder. Mine had same issue.
Dec 29, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
I have a Hoover S3630 canister vacuum and the brush works on the bare floors but will not work on carpets.
does your vacuum have an adjuster knob on the front? if so try raising the unit so that the brushes don't bind up on the rug and burn out the belt
Dec 28, 2010 | Hoover S3630 WindTunnel Bagged Canister...
Hoover UH70120 WindTunnel TSeries problems with the cord. im a tech savy guy and have been trying to fix a cord after it was pulled to far out and now wont auto retract, but just cant find a way to pull...
You will probably have to replace the cord winding mechanism. I have never had any luck trying to repair one. Cord retracters are great when they work but it seems like they always go bad before too long. On many units you can't even replace the cord if you get a bad spot in it, you have to buy a new cord reel which can get expensive.
Jul 21, 2010 | Hoover UH70120 WindTunnel TSeries Rewind...
My vacuum cleaner has power through the switch and through to motor but will not go .The motor has no short in the winding what can be wrong
If you are sure voltage is going to the motor, then replace the motor brushes if its older than 4 years as they will be worn, what you may find is a broken wire @ the coils......
Apr 13, 2010 | Hoover S3630 WindTunnel Bagged Canister...
How to put the bag on a windtunnel canister s 3630 ?
on the bags there is an arrow to show the direction to install on the bag holder.
Jan 25, 2009 | Hoover S3630 WindTunnel Bagged Canister...
Hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Hoover S3630 WindTunnel Bagged Canister Vacuum Logo
557 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
