Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD 440
The machine makes a very loud banging noise when spinning on final rinse/spin. The transit bolts have been removed and the machine is on an even surface. What now?
  • 57 Answers
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Posted on Jul 15, 2008
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer makes loud banging noise on spin cycle and walks across the floor. The drum rotates fine on other cycles and belt seems to be intact
Have you removed the bolts at the back of the machine. they are there to help stop it getting damaged in transit but if left in when in use it vibrates violently and moves a lot read manual and look at back to see if bolts are left in and remove them if so. hope this helps.
Dec 28, 2010 | Samsung WF337AA Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin cycle
several points. did you put in transit bolts for move and forget to remove them? is machine sitting square on all four legs? is it sitting on a suspended floor? if joist spacing is wide, then this can result in vibration.
Jun 17, 2007 | Hotpoint Ultima WD72 Front Load...
Shakes violently and bangs on spin
transit bolts not removed. also can be caused by motor not winding up gradually into spin - usually a motor tach fault. most likely cause is transit bolts
Oct 18, 2006 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
