Question about Dell Computers & Internet
Cd rom I purchased a cd rom from dell but they recommended on that was aburner also my computer had seperate drives I have installed it the cd rom is working but the burner is not I would like to know if I was supposed to disconnect wires from the old burner?????
    Sergeant:
    Champion:
  • 271 Answers
No if the old burner is working fine you do not need to remove that...anayway even if the old drive is not properly functioning it has no effect on other drives...
You are having a another problem
1. You need to have a proper burning software to burn disks...
2. There also can be lose conections between data and power cables
<PLEASE RATE ME AS FIXYA>for my help......................
Posted on Jul 25, 2008
Cd drive door was jammed and so i deleted the High and Low filters using regedit and now the dvd rom will not write however it will read. How do i fix the problem...im using a Dell xps 400 which has a...
You can go to dell's website support.dell.com to download the firmware of the dvd/cdrom. if you want to knpw the exact model of your drive you can check it at device manager,to dell's website Use your service tag to see the list of the drivers for your system when you go to support.dell.com click drivers and downloads.
Jul 20, 2010 | Dell DVD-rom DVD Drive
My dell inspirion e1705 cd and dvd drive isnt working how can fix it?
there's not much "fixing" that can go into cd drives other than getting a cleaning kit and making sure the lens doesn't have any junk on it. If you clean it and it's still not working, get on Dell's website and order a replacement.
Nov 10, 2009 | Dell Inspiron E1705 Notebook
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Cannot get CD-ROM to work,to come up on screen.
Ok with that you need to insert the disc and then go into the my computer section of your computer and then in the CD rom drive you should see the disc and you will click on it to start the process. However if that does not work then your CD rom drive is defective and you need to purchase a new one.
Jun 17, 2009 | Computers & Internet
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Need to instal cd/dvd rom into Dell lattitude laptop
You will need to connect to cables.1 is from the power supply and one is from motherboard.Just connect both to the ROM and start the computer.Windows will automatically install the drivers for your ROM..
Nov 09, 2008 | Dell (6T980-A01) CD-ROM Drive
My cd drive will not work. the cd goes in my computer makes some noise as if it is going round but nothing happens. it is like this for music cd's and cd rom's
Sounds like your drive motor gear is bad... Its time to replace the Unit. If its under warranty call your warranty provide, otherwise you will need to purchase a new drive and install it. Installation is VERY easy on a CD drive and can be done in only a few minutes in most cases.
However if you have reservations about doing it, I recommend contacting someone who is comfortable working on computers!
Sorry we couldn't fix it... sometimes they just break!
.D
Jul 19, 2008 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
Alun Cox
