Hotpoint aqxxd 169
Have bought one today when we try to start it it says demo on the screen and also machine is blocked can u help thanks
4 Suggested Answers
SOURCE: what does f12 mean on
Hi, I think the F12 Error means lack of water or water turned off, check that first, if water is turned on then turn it off disconnect the hose from the machine, then hold the hose in a bucket and gently turn on the hose tap to check if water does flow, if it does check the valve on the back of the machine, there is usually a small filter in there that can get blocked, these can be pulled out by a small tab on top of the filter using a pair of pliers, clean it and then put it back in reconnect the hose and turn the water back on, try the machine again, if its still the same it could be a faulty water valve that will need replacing.
There is another reason F12 could appear which is a faulty PCB or wiring harness fault, but generally the above should be checked first.
Here's a picture below showing an example of the valve with the filter in blue, you might just be able to see the tab on the filter.
Hope this helps.
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: my power tripped the other
(If no one else answers here is how to obtain a manual!)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 28, 2011
SOURCE: My Hotpoint Aqualtis AQXXD 169 PM is adding time
My hotpoint aqualtis dosent seem to be heating the water up on a cycle and ideas??
Posted on Jan 04, 2012
My power tripped the other day and when I remade the breaker the washing machine (hotpoint aqualtis aqxxd 169) has come back on but in Polish!!! how do I reset it to English??
John C.
May 28, 2011 | Washing Machines
It keeps coming up h20 on lcd screen
(Quote)
Error code H20
If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.
If your machine IS in demo mode come back to me and I will tell you how to get back to normal mode - it's too long to put in this solution ;-0)
John C.
Apr 25, 2011 | Hotpoint Ultima WF865 Front Load Washer
What does f12 mean on a hotpoint aqualtis washing machine aqxxd 169pm
Hope this helps.
Feb 11, 2011 | Washing Machines
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
Hotpoint ultima fdw80 is displaying demo how do i get it off
try holding resting it by holding start button or unplug for 5 mins hope this helps
Nov 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
How do you turn off demo mode on hotpoint ultima dishwasher
Hello leedowns1,
You can take it out of demo mode by pressing the "on/off " and "start/reset" button together until "d of" appears. Hope this fixes your problem.
Thanks,
edgin96
May 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Aqualtis AQGD 169 S F12 problem Please help :-(
ok, I have just had the 'blocked pump message and after much playing around I have solved it.
Pull the machine out and take the drain out and place in a bucket. Then tilt the machine on its side about 30 to 45 degrees so you can get a hand underneath. At the front there is a black rubber pipe-squeeze this a few times and then run the machine on a pump cycle. Put water in machine (i used a bucket) and repeat. You should get the foul smelling gunk out of the pump. I did this about 4 times and finally the water comes out clean and you should be ok.
Regards and good luck,
Matt
Jul 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Demo Mode
Try pressing the "on" and "start" button together for over 5 seconds..............
Oct 20, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
