Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Wont fill with water
I have cleaned the inlet screen, i have 24 lbs pressure on the guage going to the dishwasher, we can fill the dishwasher manually and works fine,, but when you drain it,,, the dishwasher will not refill.
any suggestions
  • 38 Answers
Clean the floats inside the wash tank. If they get fouled, they will "trick" the machine into thinking it already has water in it
Posted on Aug 20, 2008
Aeg 60870 dishwasher water not getting in
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG 24 in. Favorit 60870M Free-standing...
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
WATER DOES GO IN BARELY. MOST LIKELY STUCK WITH THE STONE FROM PIPES. WHERE IS THE INLET FILTER TO CLEAN IT.DISHWASHER GOES THRU CYCLE BUT WITH NOT ENOUGH WATER DOES NOT CLEAN .
the water inlet valve has a screen on the water line connection side. it may look clean but most likely the residues have entered the vaslve and is restricting how much water can enter the unit. most units need to have the water fill to just below the heating element.
the water should just touch the element. if it does, water is fine, then it might be a circulation problem with the water pump being plugged, check to see if the pump is plugged.
Dec 31, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Water doesn't fill after 50-60 secs of valve
Float valve is not used in normal cycle, it is a failsafe method. Energy conservation issues dictated less water during washing.
Oct 31, 2009 | GE 24 in. GSD5500G - Multiple Color...
No water is coming in to dishwasher. Kitchenaid kudk031twho
measure the voltage to the water fill valve. it should be about 120 volts in fill mode. if it is, then the inlet screen may be plugged. turn off water and disconnect pipe. examine and or clean screen. if screen is clean (some may not have one) and it has 120 volts applied to it then you need to replace the fill valve.
Oct 27, 2009 | KitchenAid 24 in. KUDI01FL - Multiple...
Top rack won't clean
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Jun 08, 2006 | Whirlpool 24 in. GU1500XTLS Stainless...
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
435 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
