Question about Seagate (ST380011A) 80 GB IDE Hard Drive
Hard drive settings
Need jumpersettingss
  • soundboy200 May 05, 2009
    SAME THING IS HAPPENING TO ME
    Scholar:
  • 46 Answers
hard drive settings - d5e7986.gif Jumper settings for Seagate ATA/IDE Internal drives <20gb & greater
For older/smaller drives visit www.seagate.com
Posted on Jul 13, 2008
  • SmarT-Arse
    SmarT-Arse Jul 14, 2008
    Jamesj2 please dont forget to rate my solution if you found it helpfull !!
That is right i had the same prob but as soon as i put the jumper in the master got full 80gb.
Posted on May 05, 2009
HOW TO BUILD HARD DRIVE IN PENTIUM
do you mean the magnetic device that records data if so you need to purchase either a Sata type or a IDE type depending on your motherboard hard drive interface. Press F2 to get in to bios settings and set up Hard drive settings to Auto or to the type of hard drive. Then you need to install an operating system by setting bios to boot from the cd rom or a usb memory stick depending on motherboard and hardware connected to motherboard.
Aug 13, 2014 | Computers & Internet
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
How to slave hard drive?
Mar 19, 2011 | Samsung (MP0804H) 80 GB Hard Drive
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
How can I install my hard drive without the cd?
HI jamarrfinney
If you only want to install on your hard drive as backup, cd is not needed. just set the hard disk jumper to slave for IDE hard disk. If you are using SATA hard disk, no need to set jumpers, just insert the cable and then set the bios setup hard disk as a second hard drive (if necessary)
regards
Jan 11, 2011 | Computers & Internet
Im trying to install my harddrive but im not sure about the jumper settings
If you are installing the hard drive in the desktop computer, and this is going to be the boot disk then the jumper should be set to MA (Master) and the drive should be connected to the end of the data cable and the other end of the cable should be plugged into the 1st disk controller.
If the BIOS does not detect this as the primary hard drive then the jumper will need to be set to CS (cable select). Check the BIOS again to see if it detects the hard drive.
If you are installing the hard drive as a 2nd hard drive and you are putting it on the same cable as the 1st hard drive then the jumper needs to be set as SL (Slave).
If you are installing the hard drive on the 2nd disk controller and there is no other devices on this data cable then it does not matter if it is set to MA or SL. but if the is a CD/DVD drive on the cable too then the jumpers must be set differently on each device.
Dec 05, 2010 | Maxtor Hard Drive
I need the jumper settings for Maxtor N256 hard drive.
Hard drives have three jumper settings on them.
1.MASTER---MA
2.SLAVE---SL
3 CABLE SELECT----CS
If you have a hard drive on the end (last) on the ribbon cable connectors, then it is the master drive, and should be jumpered as such-- the jumper should be on the MA pins, any drive in the middle of the cable is jumpered as slave and should be on the SL pins.
CS usually causes problems, and I do not use it.
There are no jumpers on the motherboard that need to be changed for the hard drive. The only other settings for the hard drive are in the BIOS.
Please vote 4 thumbs up!!,
James.
Apr 23, 2010 | Maxtor Hard Drive
I need to set jumpers on hard drive Maxtor Maxline plus II y653z5le as a secondary drive. How do i do that?
on the drive there should be a diagram for how to set the jumper settings. you want to set it to slave.
Jun 13, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
943 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
