HP PSC 2410 All-In-One InkJet printer default settings
HP PSC 2410 All-In-One InkJet printer hangs up and makes funny noise from scanner. How can reset to factory settings to cancell the scanner in printer memory.
when turn it on scanner is not working properly, making funny noise and windows screen is not openingwhen turn it on scanner is not working properly, making funny noise and windows screen is not opening
when i turn it on my hp psc 2410 photosmart all in one printer light, is coming , scanner is not goimg and coming back start making funny noise also scrren isnot opening.when i turn it on my hp psc 2410 photosmart all in one printer light, is coming , scanner is not goimg and coming back start making funny noise also scrren isnot opening.
This is a common problem with these models. Any ways this is a problem with the cable connecting from logic board to the scanner assy. replacement is the best solution
I have the same PSC 2410 and contacted HP the print software is included in Leopard 10.5 but the scan is not. They have "no" plans on producing software and went as far as to recommend third party scanner software to make it work.
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
scanner replacement is needed as this cannot be repaired,the lower printer part is perfect just the scanner parts needs replacement.it is also costly to get replaced.
You have a problem with your scanner software or your operating system.Try connecting you scanner to another computer, install the software, and try scanning.
I have experienced this problem numerous times since owning theprinter, and usually a full reset (# and 9 on power-up) has resolvedit. Not this time, however! Following Guest's advice above, I visitedwww.fixyourownprinter.com and found the solution: cleaning the glass. Thank you, Guest!
printer have browes symbol on display and sound arise in scanner light
