Remove your av cables on the back of your flat screen,I have a Wii and it is doing the same if there are av cables plugged in the back of my screen it just will not work,this is due to certain products that have software floors or bugs that they only work with one cable so its HDMI or AV your choice
if the ps3 is set to hdmi it will not work threw the av cables. you need to change the settings on the ps3 to use av cable. its mostly set to hdmi as factory setup .
hello chis, it may the ps3 your having trouble with connect ps3 to hdmi 1 reset the ps3 by doing this. press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button this will reset the display setting on the ps3 you should get1080p if this dfon't work feel free to get back to me thanks
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI If the AV on your PS3 works and not your HDMI sounds like Display Settings issue... If you have done all that, that is strange if it still doesn't work. There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
