Question about Brother IntelliFax-2820 Laser Fax
INTELLIFAX 2820--PAPER/SCANNER JAM
THX FOR PROMPT REPLY "GOLDFLACK!" RE-STARTED SEVERAL TIMES AND DISCONNECTED TEL LINE & POWER. STILL DID NOT SOLVE PROBLEM. ALSO NO "SOFTWARE" CAME WITH THE UNIT OR CANNOT BE FOUND??? YOUR THOUGHTS/OPTIONS, PLS.
THX AGAIN,
Biche
bob.smither@opsreps.com
  • Jim Keysor May 11, 2010
    What is your problem??????????????
Go to brother & download driver for printer. good luck !
Posted on Sep 04, 2008
I AM RECEIVING PAPER JAM AT MY BROTHERS INTELLIFAX-2820 THERE IS NO PAPER JAM AT ALL( I CHECKED IT COMPLETELY). AND FAX MACHINE KEEPS RUNING UNTIL I PUSH THE STOP KEY AND GIVES THE PAPER JAM MESSAGE.
Where is the paper jam?Jou can take the cartridge out and look if the sensor actuator is in it's plase.if you open the back door look for small pease of paper that might stay behind or a paper that did not go through otherwise take the paper tray out and look in the botom of the machine for sensors or peases of paper
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
My fax machine brother 2820 shows document jam. How can i solve it. it shows - clear the scanner jam, then press stop. How can i get tht
for this one you need to make sure there's no paper that was cut while you are removing the paper that was jam, try to clean the rollers with a clean paper the one that feeds the paper . when your done .Lift the printer upside down and remove the cartridges try to shake it for 5x .. I believe the upper portion portion of the printer is removable make sure there are no foreign objects such as ballpens , sharpeners etc...
Hope it help
May 22, 2011 | Brother IntelliFax-2820 Laser Fax
I can't get it out of sleep mode; can't find the "Menu Map" either
It may be that the board has a glitch. I usually solve that problem by disconnecting the tel line and power cord. Wait a few minutes, then re install the power cord, then the tel line cord. The machine then should go through a self check and the sleep mode will be disabled until the next inactivity period (5mins) During this time you can go through the set-up and disallow the sleep mode completely.
Oct 06, 2010 | Brother IntelliFax-2820 Laser Fax
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
May 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Nov 21, 2007 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
234 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
