Question about Garmin StreetPilot c550 GPS Receiver
Garmin c550 Bluetooth problem
How did you fix your bluetooth problem? I have the same problem a few months after you.
Honestly I just kept playing with it until it finally took.
Posted on Jul 15, 2008
I have lost the bluetooth
The Bluetooth symbol on the bottom left of the screen will not show up unless the unit is linked with a compatible phone and Bluetooth is turned on. When the phone is not connected or the Bluetooth is turned off, you will not see this icon. The same thing goes for the Traffic icon. If you do not have an active traffic receiver connected, the Traffic icon will not show up either.
Apr 16, 2010 | Garmin StreetPilot c550 GPS Receiver
I cannott connect my lg xenon phone to my
Unfortunately, not every Bluetooth enabled phone is compatible with the C550. I believe Garmin has a list of compatible phones on their website. It is possible your phone will not work with your GPS.
Nov 17, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin c550 phone book problem
Garmin support center----tomtom support center
http://www.gpscentral.ca/contactus.htm
all the gps information for 660 number model
http://gpsinformation.info/nuvi/660/660.html
just model number is different but the system is same
hope this helps
Nov 25, 2008 | Garmin Nuvi 660 GPS Receiver
Try deleting the pair from both the phone and the Garmin.
Then, retry the pairing sequence.
Hope this helps.
Sep 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Bluetooth connection
If you have tried to connect from the unit and from the phone, and neither finds the other, or they won't connect, it is possible the phone may not be compatible with the unit. Not all Bluetooth devices are compatible. Your best bet would be to go to Garmin's website and check the C550 for compatible phones and see if yours is listed.
Feb 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Bluetooth
Are you trying to connect from the phone or from the unit? If you haven't already done so, try connecting either way. Let me know if you have any luck.
Jan 14, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin 660 gps Bluetooth problem
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Oct 05, 2007 | Garmin StreetPilot c550 GPS Receiver
Bluetooth enabling
Does it work properly otherwise? Is this the only place it gets stuck?
Sep 16, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
