Question about Arris Touchstone 450a (CM450) Modem
Arris Modem connected to Mediacom Service
I currently have Mediacom Cable service and a Arris modem. I am capable of getting on the internet, I have good quality cable tv and I can make outgoing calls on my telephone, however I can not receive incoming calls at all. I am using my cell phone to call my home phone. The home phone does not ring at all. Also, my fax machine is no longer working. Can u help?
  • 1 more comment
  • Anonymous Mar 18, 2014
    My wifi light no longer turns on. I have the ARRIS DG860. I am currently using the ethernet cable. I had wifi just fine yesterday. I don't know how to fix this.
  • Anonymous Mar 20, 2014
    Home phone does not connect to other numbers. I have called you and you fixed the telephone sound but I cannot call anyone as there is a silence after dialing the numbers
I didn't have incoming calls for a year (didn't mind, no telemarketers). But I fixed today.
Check with your home alarm company. Turns out they can download a signal. No, it wasn't the computer's internal modem, it wasn't the phone/cable company or the arris modem.
No need for service call.
Posted on Jul 31, 2008
How do I get wifi to work after the service guy has left
If he has activated WiFi, your WiFi capable devices should be seeing an Arris-XXXX wireless network. Just select that network and use the password the service guy has left you.
Dec 19, 2014 | Gateway Arris Touchstone Telephony Cable...
We are currently running Comcast internet and phone through a Netgear Wireless-N 300 Router and an Arris TM502G Modem. Our phone service works fine, but the "Link" light isn't showing up for...
There's a reset button on the back of the modem. It'll power cycle it. That should work and if it doesn't make sure everything is connected and tightened.
Jul 29, 2011 | Arris Touchstone 450a (CM450) Modem
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use for ip address, I think
check direct tv box for internet settings for it's ip address should maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
Hi, Can i chenge my up and down strm speed in Windows 7 for Arris cable modem?
No, unless you pay your Internet Service Provide more money per month to get higher speeds.
Doing so is probably a violation of the service-contract between you and your cable-modem-using Internet Service Provider.
Apr 08, 2010 | Arris Touchstone 450a (CM450) Modem
I use the RCA model 425 modem through Media Com. My wiring for internet enters a bedroom. Now I also want to hook up a tv using this modem. A Media Com employee suggested using a splitter. Will this work...
Theoretically you can because the purpose your cable serves is a conduit for data transmissions. Just a few cautions here. Just as in any circuit, the more the wire is spliced,split, or anything that taps into it on its way . to the modem will add resistance to the line, thus it could degrade or "slow down" your signal. There is a splitter I know mediacom haves that will help with lessening this effect.
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Can I get cable tv on my computer?
Download and install Internet TV software.
I f u want cable TV you must have a TV tuner Card and Cable connection.
if it helps Rate me
Jun 27, 2009 | Arris Touchstone 450a (CM450) Modem
Free internet?
Yes, You need to contact your a local cable company and sign up for service. Tell them you own your own modem and you will need to give them the HFC Mac address. Once they enter you into the system and your a paying customer everything should be smooth sailing.
Mar 23, 2009 | Arris Touchstone 450a (CM450) Modem
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Arris Touchstone 450a (CM450) Modem Logo
1,105 people viewed this question
Top Arris Computers & Internet Experts
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
