RCA TV 1990 model no.F20163wn
Will I need a converter box to covert Anolog to Digital before Feburary 2009 when the digatal output starts. What kind? Where purchase? Can I apply coupons there? Due I need pass -through type or should I just save the money, please elaborate?
    Genius:
  • 1,139 Answers
The site to check is http://www.dtv.gov/ This site will have the information you need
Posted on Jul 14, 2008
Dose my tv need a converter box for digital tv it is a RCA model number L26HD35D 2009 April
If your TV does select digital (decimal) channels when turned on, it needs a DTV converter.
Nov 25, 2016 | RCA L26HD35D TV
Is Orion TV model 1929 ready for Feburary 17, 2009 Digtal conversion without the converter box ?
is the model number correct? Can't find the details of your television.
Does your tv use digital input? or analog if its analog then you need the box.
May 04, 2008 | Televison & Video
CAN I connect 2 tvs.to one converter box and how.
If you're using a box that has an RF (antenna) output on channel 3 or 4 to the TV, you can insert a splitter and feed two sets. A splitter looks like this:
It takes the signal in on the single connector side, and splits it between the two output jacks on the other side. You can find splitters at TV retailers, Radio Shack, and even at Home Depot or similar stores in the electrical section. Run a cable from each of the output jacks to the antenna connectors on the two TV sets. Each TV will need to be tuned to the converter box output channel, and both sets will get the same program (whatever channel you have selected on the converter).
If the converter box has audio and video output jacks and the nearest set has an AV input, you can connect that set with the same kind of cable you use to hook up a DVD player (RCA plugs on the ends) and select the AV input to see the converter box signal. You would run a cable from the RF output connector of the converter to the second set's antenna jack. Then you wouldn't need the splitter, and the set using the AV inputs would get better quality picture and sound. Again, each set will get the same program as determined by the converter.
Hope this is what you need to get going. Thanks for using Fixya!
Dec 17, 2010 | RCA Analog (RCA) to Digital (VGA)...
What model of a conveter box do I need to set up the TV ?
Different TVs need different type of converter box to work properly. If your TV has audio video [A/V] input socket, go for a converter which has A/V output in it. If your tv has no A/V input, and only one ariel socket is there, buy a coverter which has RF output in it. Most of the coverters have both A/V and RF. Just buy that type of converter and it is good for you if you are not sure about the matter.
Oct 16, 2010 | Craig CTV-41331 13" TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Analog to Digital converter
Ur tv a LCD or Plasma tv?No,LCD and Plasma Tvs have a Digital tuner inside the tv to recieve free air DTV.Not require a Digital coverter box,if u have a LCD tv or a Plasma tv.U must have good antena thought like a roof or a digital antena,so ur tv picture don't cut in and out very often.
May 29, 2010 | Olevia 332V LCD TV
RCA DTA800B1 coverter box & LXI 13" TV - need remote code
You may have to try using a separate universal remote control.
Feb 07, 2018 | Apex Digital AT1308 13" TV
Will it work in 2009
the answer to your question is yes but, only if you are using an areal antenna to veiw tv, you will need a converter. the change over only affects those who use an antenna and have a NTSC tuner.
if you have satelite, it is already a digital format no converter needed. the sat box is the converter
if you have cable you will not need a converter. most cable companies will still pass thru the anolog signal. but getting the digital service is not a bad thing.
Mar 24, 2008 | Televison & Video
YOU WILL ONLY NEED A CONVERTER BOX IF YOU DO NOT SUBSCRIBE TO CABLE OR SATELLITE SERVICE AND RECEIVE YOU CHANNELS THRU A REGULAR ANTENA. YOU WILL NEED THIS BY 02/2009. HAVE A NICE DAY.
Mar 19, 2008 | Toshiba MD13P1 13 in. TV/DVD Combo
Televison & Video Logo
798 people viewed this question
Top Televison & Video Experts
