Question about Panasonic Microwave Ovens
Microwave Oven was running, made a funny noise, and now has no power. Breaker is not tripped.
  • 1 more comment
  • digitalage Jul 22, 2008
    Here is a bit more detail: Placed the coffee in the microwave to heat. Pressed the start button, a few seconds went by and there was a funny noise and then no power at all.
    I saw from another similar post that this could be a shorted high voltage capacitor.
    But also checking the door switches and door mounts would be warranted.
    Can you provide info on how to do this?
    I have worked on computer logic boards changing out components, but very little experience with soldering. Does this repair call for soldering?
    Thanks.
    I've done some small soldering jobs, so this probably would not be bad.
    How do I locate the high voltage capacitor?
    Thanks for the speedy replay, by the way.
    The Model is a Sharp R-1450 manufactured in 1994.
  • 958 Answers
Hello digitalage,
the high voltage capacitor in a microwave oven is not soldered to a pc board. it looks like a capacitor that is use in air conditioning units. it is oval in shape and has terminals on top. usually two terminals. it is clamped at the flooring of the microwave oven...
i hope i answered your inquiries...
tnx,
drcool
Posted on Jul 29, 2008
    Master:
  • 726 Answers
You mayhave or yes u have blew the heating element ill tell u the truth its cheaper to by a new microwave ,,,,,dont open it it contains high energey it will cause serious harm even if it is not plugged in. even if it sat for days it still holds the energey
  • chris07551 Jul 29, 2008
    still if ppl say the capacitator its not cheaper then a new microwave these days and still dont open it if u dont no any thing about them it will give u the shock of your life
  • Panasonic Master
  • 13,433 Answers
Check the fuses if any are blown replace them. Is it under warranty the oven? if it is, then you can get it repaired for free contact your dealer / panasonic in that case.
Posted on Jul 22, 2008
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
Hi, in my home every electical applience works well. But when i switch on microwave oven the power to house will go off. MCB trips i think oven drawing more current/power. what might be the problem...
There is a dead short in side the microwave... this is causing the breaker to trip...however you should also replace the breaker to the microwave, as that should trip before the MCB...unless both are tripping at the same time...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 12, 2011 | Westinghouse WST3504 Microwave Oven
The microwave is making a funny sound when turned on and it is popping the circuit breaker
try plugging it on another circuit with no load (a circuit with nothing els connected) if you have other things plugged with the oven (toaster, slow cooker, etc..) it could trip the circuit breaker as a microwave oven needs a 15 amps circuit to operate properly...
good luck!
Feb 22, 2011 | Tappan Microwave Ovens
Runs for 20 seconds and trips breaker. making a loud noise when running
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
This oven is fitted to my new (to me) rv. the convection bit is fine, but the microwave trips the 15A breaker. have changed the breaker, still trips.
Yes the breaker is to stop firs etc, you should NEVER EVER simply re-set a breaker without finding out WHY it tripped. I suspect your oven has developed a Short Circuit fault. Please DO NOT touch it while plugged in you risk electric shock. Please remove from power and get it looked at by a qualified person. Please ask for "Quote" before proceeding with any work. a lot of the time replacement is cheaper than repair.
Mar 19, 2010 | Sharp R-1874 Convection/Microwave Oven
My Model MH7140XFB-1 over the overn Whirlpool
There is an internal fuse. The cause for it blowing will have to be determined.
eric
Aug 06, 2009 | Whirlpool Microwave Ovens
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Model JVM 1650sho1
is there a fix for this problem mine does the same thing, i changed the powerstrip and it worked fine for a month, now it's doing it again runs for too minues or so then it trips the circuit breaker in the power strip
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
