Question about Kenwood KDC-X590 CD Player
Display is OUT but everything functions....... what to do?
My display on the faceplate has stopped working, is there a battery in this unit or some type of recall or fix for this ?
Help! same thing but now everything stopped working
  • 132 Answers
SYMPTOM: No Display.
COUNTERMEASURE: Re-solder the following components on PCB X34-415:
R43, R44, R46, R47, R48, R49, R50, R51, R55, and R57.
Ok so if you remove the top of the unit and cd player down the right side you see a line of surface resistors that say 2R7 on them, they all need to be resolders to the bord theres 9 total.
Posted on Jul 25, 2008
DISPLAY ON MY KENWOOD STEREO STOPPED WIORKING
I also created a tutorial on fixing faceplates with 2R7 resistors (refer to my tip).
But, your unit will have a different chassis, as the faceplate is also a video display.
First you need to determine if the buttons on the faceplate are operating the various functions. If the buttons are NOT operating, then the faceplate itself (or connection to the main unit) can be considered faulty.
It's highly probable that the RIBBON cable (which connects faceplate to the inside of the unit) may be defective - this is common in some Kenwood units.
Try searching Google or youtube for ribbon cable repairs etc.
Hope this leads you in the right direction.
Cheers,
Scott
Dec 29, 2012 | Kenwood Car Audio & Video
I just followed tech48's solution by resoldering the resistors on the main board.
Dec 29, 2008 | Kenwood KDC-MP632U
OEL Display not Working on my Pioneer DEH-P7800MP
Do you take the faceplate off often? If so mayeb you could try wiping the metal contact plate on the unit b4 u put on the faceplate.
Jun 02, 2008 | Pioneer DEH-P7800MP
Faceplate not working - will remote solve problem?
PLEASE FIRST CHECK THE FACEPLATE TO HEAD UNIT CONNECTIONS (WHERE THE FACEPLATE CONTACTS THE HEAD UNIT ).
THEN IF U ARE SATISFIED ,REPLACE THE ENTIRE RECEIVER.
May 10, 2008 | Pioneer DEH-P4700MP CD/MP3/WMA/WAV...
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
My DEH-680MP Stopped Working....
I just had the exact same problem today, but the radio responds to the remote and buttons on the face. I can eject cds and everything but the display will not work when the face is up. I cleaned the contacts on teh face pice with no resolution to the problem.
Mar 14, 2008 | Pioneer DEH-P680MP CD Player
CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Jan 06, 2008 | Kenwood DPX-501 CD Player
VR500CSBT Reseting itself when I remove the faceplate
no man, you should take a direct line from the car battery to the unit, then you radio station will be saved all the time, do it in specialist in cars, just tell it that
Dec 04, 2007 | Roadmaster (VR500CSBT)
The problem is not the faceplate for any of you, it is inside the main unit. If you know how to solder, you can fix is very easy. First take the top off the unit, there is 1 screw in the back middle. Then take the CD player out. It has 2 screws holding it in at the front corners at the bottom of the CD deck. Use a number 2 phillips and take out the gold screws holding the CD deck in place. Then you can pull out the CD deck, and be careful not to damage the ribbon cable connected from the CD deck to the main board. The deck can just sit up and over to the left to get it out of the way for what needs to be soldered.
Look inside the main unit on the board and you will see in the front right corner a series of surface mount resistors all connected in series. Just reflow that solder on them with a small amount of new solder added and the display will once again work perfectly. That solder is very heat stressed, that is the problem. I have fixed dozens of these over the last few years. Make sure you put it back together the same as it came apart, and you are done.
Nov 28, 2007 | Kenwood KDC-X590 CD Player
Initialization Problem
Hi, I'm not an expert but if you phone 0113 202 1040 a company called unicar - they have a specialist repairs department that may be able to help you. regards
Nov 12, 2006 | Kenwood Sirius KDC-MP925 CD Player
Kenwood KDC-X590 CD Player Logo
125 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
