Question about Garmin StreetPilot c550 GPS Receiver
Garmin 660 gps Bluetooth problem
Ok, i've tried everthing to fix my problem including resetting my device, deleting and setting up the bluetooth config, also downloading and installing the FileBlueTooth.zip file to no avail.
Here is my problem: It was all working 2 days after i brought it and configured it. Could see all my contacts, txt messages and other stuff, make calls through the gps to my mobile (Sony Ericsson W850i)
How, when I start the phone and the 660 it detects and connects, I can see my txts and contacts on the 660 via bluetooth to my mobile, but the Bluetooth disconnects after 10secs on the 660. When I enable bluetooth on the 660 it just sits there with the message Enabling Bluetooth.
I've updated the software from Garmin including the Bluetooth patch...
Any Ideas!!!
Anthony My garmin was working fine and while driving, it started an Bluetooth update and stopped at 86%. Since then, no way to use Bluetooth.
I update the software from Webupdate. I reloaded the programe for C550 (not the flash) still not working. I reset the unit, removing all personal information. Still Bluetooth stays in disable mode.
Finally I returned the unit.
Posted on Jul 14, 2008
How do i use the bluetooth feature on my garmin 260w?
go into settings and see if it has bluetooth logo icon, if not then it dont have it , if yes then go into and add device and make sure your phone is visible on bluetooth settings, then search for device follow prompts
Jan 02, 2010 | Garmin Nuvi 660 GPS Receiver
Bluetooth connetion with Verizon Treo 700P
Looks like your saying you've updated your n?vi 660 to software(firmware) version 2.0, if so you're moving in the right direction. Unfortunately the n?vi 660 does support the Treo 700P but only seems to support the 'Hands-free' BlueTooth profile and this is often problematical as is the 'headset' profile with some device combinations, that's precisely why many phones and devices now support both profiles. Check the pairing information to see if you're using 'headset' or 'Hands-free', whatever you're using delete the pairing on both devices and see if they will let you pair in the other profile. Your Treo 700P is made by PalmOne (www.palm.com) so you may want to check for software updates from them. This kind of problem is down to the lack of a solid standard for BlueTooth communications and you will often find that settings that work for one combination of devices are unstable with another. Post back if this doesn't help or if you need us to clarify anything.
Aug 18, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth will not enable
This is solved in a related post by silentspoon
http://www.fixya.com/support/t236067-bluetooth_enable
I just tried it for the same problem, worked great
Apr 23, 2009 | Garmin Nuvi 660 GPS Receiver
Pairing my garmin nuvi to my blackberry
Nuvi 200 does not have bluetooth capability.
See this link:
https://buy.garmin.com/shop/shop.do?pID=9160#specsTab
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 760 is stuck on enabling bluetooth
Seems they have been having the identical problem with the 660
Here's a link to the solutions..
http://www.fixya.com/support/t179960-garmin_nuvi_660_bluetooth
The 2 best suggested fixes were probably that you need to reset the garmin ( instructions at link)
Or update the bluetooth software ( Probably the best solution)
Sad that the left hand does not know what the right hand is doing but this is what happens when you have a marketing company in one country having their product made in another... :(
Aug 17, 2008 | Garmin Nuvi 660 GPS Receiver
BLUETOOTH
Download and run the Garmin WebUpdater. There is a new version of the firmware availabe for the bluetooth.
Apr 25, 2008 | Garmin Nuvi 660 GPS Receiver
Blue tooth phonebook
The unit does not save the phone book, it loads it each time your bluetooth phone is in contact with it. To verify this, turn off the bluetooth phone, then try to access the phone book in the GPS unit. It should not come up.
Mar 26, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI 660 BlueTooth
I had the same problem, and this is how I fixed it. Now it's working fine.
Thank you for contacting Garmin International,
If you are currently running the most current version of bluetooth software, and you are still seeing issues where your compatible phone is still not connecting properly, please try the below procedure, which will reinstall the version of bluetooth you have downloaded in case there was any corruption during the transfer or installation of the bluetooth version.
1. Power the unit on
2. Touch View Map
3. Touch the ETA/Speed button in the bottom left hand corner.
4. press and hold your finger over the speedometer for 10-15 seconds until a new screen appears.
5. Touch next at the bottom of the screen until the top blue banner reads Bluetooth Status.
6. Touch UPDT P, then Touch yes.
7. At this point the unit should go to a page that says Updating Bluetooth Firmware, allow this to finish, once finished, press quit, then press and hold the back button. At this point, go back through and try to connect your Bluetooth device again.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
Note: This is for a 550c Street pilot
1) Turn on unit
2) Press VIEW MAP
3) Press SPEED in lower left hand side of map
4) This will bring you to the Trip meter screen on this screen press the round speedometer at the top of the screen for about 10 seconds this will bring you to the SYSTEM BIOS.
5) From this point forward be careful you can mess up your unit by changing the wrong thing.
6) Press NEXT until you come to the BLUETOOTH STATUS screen.
7) Now press UPDT P this should complete your update.
Nov 13, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 - Bluetooth
I fix this problem for my Nuvi 660 Europe. I found resources in Italian language only: 1 - go to http://www.garmin.it 2 - in the search texbotx (i the up left corner of the page) type bluetooth and press enter 3 - click on the 1st faq that will appear 4 - download the file FileBluetooth.zip 5 - unzip the file 6 - copy 006B055301.GCD in X:\Garmin\RemoteSW directory 7 - reboot your nuvi At this poin bluettoth would be ok newly. Bye
Aug 08, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
198 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
