Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Coffee bean does not work too well. It does not grind "fine" enough leaving coffee very light.
  • Anonymous Aug 05, 2008
    grinder stopped woring
  • 74 Answers
Depending on how old it is it can be the grinder blades that is getting bad.
Posted on Jul 14, 2008
Bean hopper is full, machine starts to grind the coffee but right before it starts to pull the shot, it stops & says "add beans to hopper".
the add beans to hopper signal most likely is triggered by the machine not sensing enough load put on the grinder (hence it thinks its out of beans) , this most likely is set by the grind (fine/course ) id say the grind is set to an improper size and the automatic sensor is picking up on that
another thing is the coffee / if its way too moist and not dry enough then its also going to trip the sensor as well
Feb 26, 2016 | Coffee Makers & Espresso Machines
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Coffee grinder is not grinding beans fine enough
Try it with less beans, or the motor is not running at full speed, no other fix
Mar 24, 2013 | Coffee Makers & Espresso Machines
Saeco primera ring, will not grind coffee, high piched sound as if there are no coffee beans to grind. Its also indicates out of coffee and of course there is coffee bean the hopper in it.
Sounds like the grind is too fine and the beans are not able to get to the burrs, try adjusting 2-3 numbers coarser. Remember only adjust when the grinder is running.
Jun 08, 2012 | Saeco Coffee Makers & Espresso Machines
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
My Saeco Vienna Black Automatica Espresso maker will grind coffee only about one-fourth of the time. Other times, it makes whirring sound and then shuts off and red "coffee bean" light comes on.
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
Nov 02, 2010 | Saeco Vienna Espresso Machine
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
64 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
