Question about Microsoft Windows XP Home Edition
Cann't write in cd/dvd
Whenever I try to write in cd or dvd error message of incd.exe shown and a debugging window opened.
  • 297 Answers
Go read this first here:
http://www.file.net/process/incd.exe.html
do as told
Reinstall a trusted dvd burning program.
Nero 7 wil work again proper without norton and SP3 installed
Otherwise other nagscreen to upgrade (Not cause by ahead but bu MS, i.e. MSindexstore bla bla error, can click it away anyhow and live with that also)
Posted on Apr 15, 2009
  • Microsoft Master
  • 2,794 Answers
DVD writing isn't possible in Windows XP without additional software such as Nero.
Do you have another DVD writing program installed in your computer?
Posted on Jul 13, 2008
  • Tim Babcock
    Tim Babcock Jul 13, 2008
    Sorry about that. That was supposed to be a clarification and not a solution. I forgot to use the drop down.
    The answer I gave from the previous message should work. If it does, can you please change this for me.
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
Hpqthb08.exe and HPQDocViewer.exe error messages
****, since you have been having many issues, I guess that your windows is corrupted.
The best way to proced is to install a clean copy of Windows, install all of services packs and updates and then install the HP software and test the printer.
I know this is a lot of work, but it probably will solve this and many other problem that you are experiencing.
good luck!
Nov 24, 2008 | HP PSC 1510 All-In-One InkJet Printer
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Satellite m 100
It is cd software that is known to mess up,so....go  and press the start key to get to control panel,open add/remove programs,and look for the incd program ,click un install ,follow the prompts and you are good to go.                                     :)
May 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Make your system virus and spy ware free. Then unistall all the softwware you needed from HP CD or Web site. Hope this will solve your problem.
Feb 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
Writing disc
There will be different answers for different people. Changing the writing speed to the slowest available (6X for me) may help you – it did not help me. However, after ruining a big pile of DVD-Rs, I seem to have found out what my problem is – there is a conflict between my Picture Motion Browser and my InCD Helper. Here is how I got to my conclusion (I am running Windows XP Professional and have Nero 6):
On Friday, I spent over an hour on the phone with Sony Support (“SS”). SS had me create a new folder on the C:\ Drive, open Picture Motion Browser, select a media file, click the disc creation icon and on the settings tab of the disc creation window: (1) change the “Location of Temporary Files” to the New Folder and (2) check “manually select a writing speed”. Then I started the disc creation process and selected the lowest writing speed available to me (6X). At 50% I got the “Authoring Tool” error and the disc would not burn.
SS next had me restart my computer in Safe Mode (hitting F8 as it starts up) and select “Safe Mode with Networking”. Then I was able to burn several times without an error (even at “Optimum Speed”). Before I got off the phone with SS, he suggested that I disable all items at startup that are not necessary.
Yesterday, I clicked “Start”, then “Run” then typed “msconfig” in the Box, then clicked “OK” to bring up the System Config Utility. On the “Startup” tab (with my brother’s help) I disabled most of the startup items because they were not needed (if my brother was not familiar with a particular program, he looked it up on the internet to see what it did). Among the programs I disabled were InCD (InCD.exe), Nero Back it Up (NBJ.exe) and Nero Check (NeroCheck.exe).
After a Restart, I then tried, in normal mode, to burn a DVD-R with the New Folder/6X setting, with no luck. Bad burn.
My brother then suggested that I go back to the System Config Utility, click the “Services” tab and check the box “Hide All Microsoft Services”, so I could see only the non-Microsoft services that were running (I had 9, which included InCD Helper).
I disabled all the non-Microsoft services, restarted and tried to burn a disc at 16X – GOOD BURN. I then enabled InCD Helper (and kept all other non-Microsoft services disabled) and tried to burn – BAD BURN AT 50%. Next, I enabled all the services except for InCD Helper – GOOD BURN. Then, did another good burn. Then another.
So, turning InCD Helper off seems to be my work-around for using Picture Motion Browser (I kept the temp files location set to the New Folder). Of course, I will need InCD Helper to format my Read-Write CDs. Maybe InCD in Nero 6 is a problem but not in Nero 8. Also, For some of you, there may be conflicts with another program.
Hope this helps.
Nov 22, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
HD error
easy fix would be to reinstall windows ;)
Jun 10, 2007 | Hitachi hts548080m9at00 80 GB Hard Drive
Nero 6 and 7 will not load
What PC are you using?
Did you try removing ll incd software and try install?
Do you get an error message when you try to install?
May 02, 2017 | Yamaha CRW 2200E CD-RW Burner
Microsoft Windows XP Home Edition Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
