Gas range ge profile xl 44 spectra everything works but the oven , broil works, turns on ex. 350 bake and it shows err. also bake locked, don't know what to do to fix it
does it not bake or broil? if this is the case, it could be the control panel. however if one or the other of the bake and broil functions work then it would most likely be an ignitor. check to see if your broil and bake ignitors glow. to access the bake ignitor you must remove the bottom panel from the oven but you can probaly see it gowing without removing the panel. the broil ignitor should be in plain sight.
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Sounds like the switch module is defective. You might get lucky if you power down the stove for half an hour and then reapply power. Sometimes they reset. If you, enjoy. If not, you will need that module.
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Ted, you probably have a bad ignitor. If you have a meter, you can do some checks to rule out the board. Take the back top panel off and on the board you will see four wires..from left to right they should read L1, neutral, broil and bake on the board. Broil and bake will be marked as BR and BA. Set the oven to 350 and press bake, you should have 120V from BA to Nuetral. If so your board is ok. You should also hear a click after pressing bake. 90% of the time it's the ignitor, part number WB13K0004. Be care when testing with live power. Catriver..post back.
