Question about General Time Corporation Audio Players & Recorders
Collectible Talking Clock Stopped Working
I have the product described below manufactured by General Time Corporation, Norcross, GA. It has stopped announcing the time each hour. Is there anywhere I can get it repaired?
Ken Kloman
kenk@kloman.com
  • kenk381 Jul 13, 2008
    I thought more of the info would show on the post:
    The clock is a model 33124 Westclox Looney Tunes "Talking Character Wall Clock"
  • kenk381 Jul 14, 2008
    Problem solved! Thanks for your help.
3 Suggested Answers
  • 1153 Answers
SOURCE: 79 buick regal clock repair
Is this the only thing that is not working on the radio? If so, then do you want to try to fix yourself or send off?
Posted on Sep 06, 2007
gopakumarg43
  • 75178 Answers
SOURCE: Second hand has stopped working.
Hello
Just setup the clock once again by replacing the battery and check. If this also does not help you, the the press fitting of the second is loose. you have to open it to make it pressed firm.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
OK.
Posted on Jul 03, 2011
It stopped working. What should I check?
How about your ability to ask a complete question when wanting assistance to solve a problem?
what are talking about?
what are you referring to?
what stopped working?
who is the manufacturer?
what is the model?
what is the year of manufacture?
sorry, I would have answered without all of the above, but my crystal ball stopped working.
Apr 13, 2015 | Cars & Trucks
Trying to get a manual for a Spartus Talking Horoscope Clock. Model No.1793
I found a Spartus Talking Horoscope Alarm Clock. When I de-corroded the battery compartment at first it worked...talked. Now it has stopped talking but still keeps time and the alarm function works. It seemed to stop talking when I discovered the removable module, took it out to examine it and replaced it. Any one have suggestions or solutions to this problem. The clock is beautiful and complete. I wouldn't sell it for $99.00. Try $100.00.
I can be reached at alcrawfordloves@yahoo or 501) 279-2481. Thanks!
Mar 29, 2012 | Audio Players & Recorders
Describe your Inc. ML121RT Malibu Low Voltage 121-Watt Power Pack with Timer Problem Clock does not keep time
If clock has slowed down or is running reversed or gets stuck on the tripper, then clock motor has gone bad.
There are no replacement clock modules for this product, but product comes with warranty.
Work-around: Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer:
Resources: including warranty links, tips, trippers, etc:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ML121RT Malibu Low Voltage...
How do you set the alarm?
I couldn't find a manual for this model, but you might be able to get information from the manufacturer. This information is from the GE site here:
In 1987 GE sold its home electronics business to ThomsonĀ®, Inc. For a time, ThomsonĀ® produced many products that carried the GE name, but now only manufactures telephone and communications products.
The items that they support but no longer manufacture include:
  • Audio products
  • Camcorder
  • Cassette recorder
  • CD player
  • Clock radio
  • Spacemaker radio
  • Spacemaker TV
  • Television
  • Video camera
For assistance with any of these older products or your current GE telephone products please call 1-800-447-1700 in the US. In Canada, call 1-800-522-0338 (English) or 1-800-522-0445 (French).
Thomson, Inc.
PO Box 671988
Marietta, GA 30006-0034
Try calling the phone number listed. They might be able to supply you with a copy of the manual. Hope this helps a little. Thanks for using Fixya!
Nov 19, 2010 | GE 74901 Clock Radio
Clock radio just stopped working.
You will have to buy a new Clock/Radio, because Emerson does not support out of warranty repairs for these Clock/Radios. What this means to you, is there is no support. No parts or service information for the service centers to work with. This is because these Clock/Radios are short productions run items and they do not produce extra parts and service information outside the manufacturer. Sorry to give you the bad news.
Apr 07, 2009 | Emerson Smartset Clock Radio
Digital clock gains time
digital clocks work of the frequency input of the power source so it is possible to have it adjusted by a technician
like fine tuning a radio frequency there may be a pot that can be tuned to mains frequency exactly
talk with technicians in radio or tv shops or possible some jewellers who work on electric clocks may help
Nov 26, 2017 | General Time Corporation Westclox Bell...
After a few months my daughter's MP4 player stopped working. Just won't turn on.
This is from the Kaser website..
If the product becomes defective during the limited Warranty period Kaser Corporation will repair or replace any defective component at no charge to the original owner, subject to the limitation and requirements listed.
The following is required by the Kaser Corporation when requesting warranty service: Check your retailers return policy. All purchased products must be returned to original retailers if within their return policy time period. If the product is out of retailers return period, please email a request for a return authorization number toSUPPORT@KASERCORP.COM. The product must be packed in the original carton or in suitable packing offering similar degree of protection. To avoid scratches or other damages to the product during shipping separate items, such as the player, cables, or ear phone, should be individually wrapped and placed in the same package. This will also reduce any extra cost of return freight/postage. Please include a copy of Proof of Purchase
For details, click this direct link...
http://www.kasercorp.com/productcart/pc/kaser-warranty.htm
Oct 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Sep 06, 2007 | Audio Players & Recorders
46 people viewed this question
Top General Time Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a General Time Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
