Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Starbucks barista won't pull a shot
2 1/2 year old machine. we descaled recently. when drawing the shot it has been dribbling over the filter for quite a while but sometimes it would work correctly, until this morning---it come out slightly colored light brown water (kind of like when i clean it and run the water through).
  • c61894 Jul 28, 2008
    yes, I have the same problem ..and i did just clean the grinder area and burrs...any other suggestions?
Go to this link - read the whole thing - hopefully it will fix yours.
http://www.fixya.com/support/t662074-saeco_italia_sup021_yr_red_light_29
Posted on Oct 27, 2008
  • 40 Answers
Have you professionally cleaned the grinder ( + burrs)? To do this, would have to open the machine, remove the burrs, & clean them.
Posted on Jul 17, 2008
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
How do I decalicy the Starbucks Italia Digitial?
Use a coffee machine descaling liquid or powder. Follow directions on product. Add it to water container on machine and push the descaler button "bottom right" on machine. Follow directions on screen.
Jul 17, 2011 | Starbucks Saeco Italia Digital Barista...
Time to descale
http://pdfdatabase.com/saeco-italia-service-manual.html
manual above
http://www.schwer.us/journal/2004/10/03/hacking-the-starbucks-barista-digital-italia-espresso-machine/
http://search-manual-online.com/download/manual/Perfect%20Italian%20espresso%20coffee%20-%20Spidem%20-%20Perfect%20Italian/aHR0cDovL3NwaWRlbS5pdC9pbWFnZXMvc3BpZGVtX2VuZy5wZGY
Copy/paste above to address bar.
http://search-manual-online.com/saeco-digital-italia-espresso-manual.html
lots of coffee tips for it.
Apr 08, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Starbucks barista.Espresso drips.
There was an unusual high pressure problem, remove the shower and screw, then the 2 allen wrench screws and check the spring and valve seat, they may have shifted.
Mar 05, 2010 | Starbucks Barista Utopia
Not brewing shots, just spewing water out the top!!!
Yup, it sounds like you have a leak !  When the spoon is locked in place, the coffee is preventing (blocking) the water from flowing freely, and it simply finds an easier path, through a hole or loose fitting above the spoon... Depending upon your skill level, you may want to have a look inside the machine and you should be able to see where the leak is.  If it's a hole in a pipe/tube, the pipe/tube will probably need to be replaced (maybe it can be repaired...), and if it's a loose fitting, you can try to tighten it.  It might have come loose due to the vibrations from the pump. Another possibility is that you have a lot of scale built up in the system.  If you've never descaled your machine, you should do so regularly using coffee machine descaler or "CLR" available at hardware stores.  If you've ownded your machine for a while and never descaled it before, run the descaler 4 or 5 times to give it a good cleaning and then do so according to the instructions (I do mine every couple of months but I don't use my machine every day).  If you use unfiltered tap water, the scale will build up more quickly, specially if your local water is "hard".  Consider using filtered water to reduce the buildup of scale.
May 04, 2009 | Starbucks Barista Utopia
Starbucks Barista Problem
prime the steamer arm. sounds like theres air block. hope this helps
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Barista Espresso Machine Ready Light Went Out
Call Home Espresso Repair in Seattle. I've used these guys a couple of times, and they're wonderful. Once I wasn't getting any steam, and the guy told me how to open up the case and make a simple adjustment of a set screw that probably saved me big bucks.
I was actually just there today to pick up some O-rings for the steam valve. Charged me $1. And that includes replacing them for me (I had removed the stem and brought it in).
My Rio Vapore (earlier version of yours) is now 17 years old, and I give H.E.R. a lot of the credit for that.
Oh, and did I mention that back in the days when Starbucks was small (many moons ago), they were the in-house service center for all the machines Starbucks sold?
Their number is (206) 789-9513.
Good luck.
-Kevin
Oct 18, 2008 | Starbucks Coffee Makers & Espresso...
Saeco Digital Italia steam knob
Take off the top and you will see the steam valve, try to mount the parts again.
Best regards
/Mirran
Sep 09, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
393 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
