Question about Car Audio & Video
My 2004 Honda Accord EX 4door radio w/6cd changer and XM radio stopped working. Fuse is OK. Had problem with display and had scheduled warranty replacement, but battery was changed and now no radio.
  • churchguy Jul 13, 2008
    2004 Honda Accord am/fm/xm w/6 cd changer stopped working. Had problem with no display but had audio. Replaced battery myself and now no sound at all. Tested fuse OK. Honda dealer says radio died.
  • 6,487 Answers
If you know how to disasemble the radio try to open it again and take the new battery out and put it back again and make sure you put everything back correctly since before the audio was working fine,,, or if there's a radio repair near you just take it there and let them diagnose it for you and don't forget to inform them that audio was working before you replace the battery...
Hope that helps.........
Posted on Jul 13, 2008
    Genius:
  • 1,847 Answers
I dont think the radio died if the fuse is intact. here is the guide to install the radio. take the radio out and check the wiring..
http://www.installdr.com/
Thank for using Fixya..
  • Legin Varghese
    Legin Varghese Jul 14, 2008
    did it do any good...
  • 13,433 Answers
If the repair guys didn't finish the job and fix the radio if that was the point of the repair then I recommend you contact them again or why is the radio missing or not fixed yet?
My 2008 honda accord xm radio stopped working.
If it is a built in system, which is sounds like it is. Your XM receiver is not functioning correctly. I believe a replacement XM receiver is covered under your warranty if you have one with your Honda dealership.
Oct 20, 2012 | 2008 Honda Accord
My radio is working, but the display is black. What could be causing this problem in a 2004 Honda Accord EX?
There is a small bulb in the radio that is burnt out.
Goto any local honda dealership and they can sell you the bulb...its around $6
Nov 09, 2009 | 2004 Honda Accord
2004 Accord EX CD changer ERR and display blank
This is the Radio Anti Theft feature which is activated whenever there is a complete power loss to the radio (as in when it is stolen out of the car). A Honda Tech or ASE Certified Auto Tech would have plugged in a Memory Minder into the OBDII slot to not only prevent this, but also protect the Main ECM from resetting which could create drivability issue.
If the Honda is now registered in your name, take it to your local Honda Dealer. They should be able to pull the Radio Serial number without removing it like in the older Hondas, simply a matter of pushing the right buttons. With the Radio Serial Number, Your Proof of Ownership (Registration) and a Photo ID that matches it, either the Parts Department Or Service should be able to give you a Radio Code for it.
As for the CD ERR codes, the CD player probably is broken and will need to be sent out by Honda to a outside facility to be repaired. That will probably run between $250 to $350, plus the labor cost to remove it and reinstall it.
If you just bought this Honda, or any vehicle, I always strongly recommend having a Manufacture Dealership do at least a oil change on it and check what other services may be due, you might also discover it has Recalls that have yet to be completed that they can take care of for you. Catch the little problems before they ruin that Great Deal you just got buying it.
Strongly suggest you also join Hondas “OwnersLink”, you can find it on the Honda web site under Owners Resources links. In the future you can use this to recover your Radio code after you’ve been registered for awhile. Also keeps you notified of Recalls, Service Issues and even sends out Discount coupons (Latest is a $119 trunk cargo trays for $39, that is a Fantastic Deal).
Good Luck
Apr 25, 2009 | 2004 Honda Accord
We have a 2004 Honda Accord Sedan, light quit working on the radio, dash lights still work, and when the sun hits the radio display just right you can see it's still got the right info on it, it just...
This is a common issue for 2003 and 2004 Accords without Navigation. This issue has been brought upto Honda America and has extended the warranty for this issue to 7 years of 100,000 miles which ever comes first.
Feb 02, 2009 | 2004 Honda Accord
I have a 2004 honda accord coup the radio still works fine but the display for the radio stoped working
there has been some problems with displays on some accord radios honda actually had a tsb on this i would call a dealer and see if your car falls in the vin range if so they might fix it for free they put a warranty extension on the applicable vehicles if yours is not covered you will have to replace the unit
Jan 29, 2009 | 2004 Honda Accord
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
Dec 02, 2008 | 2004 Honda Accord
2004 acura tsx 6cd changer jammed
I CAN HELP YOU GET THE CODE OFF YOUR RADIO NEED TO REMOVE RADIO AND AND WRITE DOWN SER# AND EMAIL ME BACK AND I CAN HAVE YOU A NUMBER YU TYPE INTO RADIO AND IT WILL TURN ON LET ME KNOW
Jun 30, 2008 | Car Audio & Video
07 Armada
You will need to ask the dealer to replace the display again I'm afraid. I had a friend that had a similar problem with their Nissan. They had problems with display and the CD 4 times. If you try and do it yourself, that will void the warranty. Good luck
Dec 20, 2007 | Audio Players & Recorders
Car Audio & Video Logo
131 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
