Question about Cell Phones
1st Gen Apple iphone ringer icon keeps popping up unprompted and staying onscreen as if the volume up button were being held down. Only way to make it go away is to press ******* volume up button and release. But it often reappears a second or two later. Also means that I can't turn volume down when it's like this. When I did the 2.0 upgrade on Friday I briefly thought it was better and that there'd been a software glitch, but it's as bad as ever.
  • 4 more comments
  • Ashmanji Nov 17, 2008
    Ringer icon stays on. Cant get rid off it. Ringer volume keeps going down . I cannot keep it at a high level.
  • jodyu Jan 21, 2009
    I have this same problem. I turn my iphone on and the ringer icon comes on the the ringer volume on the icon goes down on it's own. Most times I have to hold the side volume control while on the phone so I can hear the caller. Also if the ringer goes down then I can't hear the phone ring either. If I hold the volume ringer so it is at it's loudest then close the iphone then it does retain the ringer volume until I turn it on again. Aarrrgh who can help???
  • buddyboy6 Jan 24, 2009
    I've got the ringer disease too. It comes on goes on low, can't turn it up and can't hear a thing. Can't hear it ring. I try to push the volume up and it keeps going down. No case on the phone. Sometimes I turn it on and off, but that doesn't always work. The damn ringer icon keeps coming on and won't let me turn the volume up.
    Do I have to get a new phone???
  • jonasion Feb 27, 2009
    Hi all,
    I have had my iphone since august 2008, and I have the exact same problem.
    1. I listen to music - and the audio levels go bonanza all the way up high. I **** out my earplugs to avoid inner ear damage.
    2. I try to remedy the problem by turning down. My iphone slowly turns down the volume while I hold the button down. As soon as I let go, it spikes all the way to the highest volume again.
    3. The same goes for conversation and all other audio related matters.
    4. And it also just decideds to turn it down automatically.
    I have tried rebooting the OS, I have installed the software upgrades. Nothing works. The button doesn't look broken and most of the time (80% or so) the phone works fine. Sometimes it just goes crazy! (Software crazy, not hardware fault crazy).
    If the phone was physically broken, then it would occur more often, not as random as now, and it would occur when I fiddled with volume, not when I started to play music.
    My iphone is a 3G, it is both jailbroken and YellowSn0w'ed, but it was not always like this, and the problem persisted even back then.
    I am from Denmark, Europe, but got the upgrade from an american friend = I don't want to send it back.
    Now for the million dollar question:
    Any solutions? App (from cydia, Installer) or even App store - which might render the physical button inoperate?
    SKO
    Hi all,
    2. I try to remedy the problem by turning down. My iphone slowly turnsdown the volume while I hold the button down. As soon as I let go, itspikes all the way to the highest volume again.
    I have tried rebooting the OS, I have installed the software upgrades.Nothing works. The button doesn't look broken and most of the time (80%or so) the phone works fine. Sometimes it just goes crazy! (Softwarecrazy, not hardware fault crazy).
    If the phone was physically broken, then it would occur more often, notas random as now, and it would occur when I fiddled with volume, notwhen I started to play music.
    My iphone is a 3G, it is both jailbroken and YellowSn0w'ed, but it wasnot always like this, and the problem persisted even back then.
    SKO
  • monindia May 12, 2009
    iphone ringer icon keeps reappearing bang in the middle....this is happening all of a sudden...somebody help as its messing with messaging n most other functions!
Is your iphone in a case? If so, remove it from the case and see if that takes care of the problem. I had the same problem and removing the case did it for me. Good luck.
Posted on Nov 19, 2008
At some point your iphone volume control button broke (maybe you smacked your iphone up against something or pressed a little too hard..it does not take much to dislodge the key). I have found no real fix to this problem other than either opening up your iphone or going into Settings & then Sound & putting the ringtone volume back up again. This will normally reset volume control (& keep it at that level for a wee while) but the slightest touch/rotation will again put you back in a situation where the volume decreases all on its lonesome.
At the moment I am testing out a theory that if do the above then exit from the menu, push down the silent/vibrate button and go back into Settings-->Sound, put the ringtone volume up again (while the silent/vibrate switch is depressed) then exit out of that menu & turn the vibrate switch back on...then the ringer problem should be solved. My theory is that the vibrate switch will reset the "default" position of the volume keys recognised by iPhone OS (meaning the OS will think the depressed position of your dislodged keys as the default 'full volume' position). Feel free to test this theory out, I am currently trying it and, out of all the methods, it has worked for the longest period... but I am not optimistic.
If you are on an AT&T contract I would recommend shelling out $200 to Apple & getting your phone refurbished. If not, then open up your iPhone & take your chances....or...live with it using the 'Settings-->Sound' method. Settings-->Sound will get rid of the annoying 'ringer' icon & once you do that it is actually not that difficult to live with the disability of an iPhone with a dislodged volume control button!
Posted on Jan 31, 2009
You can fix this by disabling volume button control. For doing so, there a app in Cydia. 1) open Cydia 2) Search Volume Button in the app list 3) download it and install it
You will lose any control from the volume button on the left (including the mute switch) but you can keep adjusting volume and mute from General/Settings. Or better, download SHSettings from Cydia and the volume toggle will be right there as soon as you slide your finger on the screen.
Posted on Nov 24, 2009
  • giorgio182 Nov 24, 2009
    CORRECTION: you can keep adjusting volume and mute from Settings/Sounds
Why is it when people call me my iphone 5 does not ring, how can i make it ring?
check the left side of your iphone and see if the ringer button is down then raise it up and increase the sound volume. Or go to settings then sounds and check the sound level. Else try to restart your iphone if it doesn't work then the problem might be in your iphone speaker.
May 28, 2014 | Apple iPhone 5
The volume on my iphone 5 is not working
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
Apr 08, 2014 | Apple iPhone 5
I cant turn on the ringer-so I miss calls
Try going to settings, then choose sounds. Try adjusting your volume by sliding the volume bar left to right.
You can also go to general, choose accessibility, then scroll down to assistive touch. Turn on assistive touch. That will put a small icon on your iPhones touch screen. You can turn your volume on or off through this button, you can also adjust your volume up or down through this. Hope this helps!
Jan 27, 2014 | Apple iPhone 4S
How do I turn up the volume control IPhone 3GS?
when you hold the Iphone in your hand with the round button with the square inside it on the bottom of the phone. turn the right side of the phone down to the floor while you do this look for 3 buttons on the side of the phone the TOP button must be pushed upwards at all times this flip switch is your MUTE switch pushed down it is in must mode switched up is sound mode.
Below this is 2 buttons the button just under the top flip switch is volume up the other one is volume down there ya go.
Please rate my solution and leave testimonial this is how i earn my achievements thanks in advance.
Apr 22, 2012 | Apple Cell Phones
Ipod touch 1st Gen turns off during restore. (Need Help!) Please?
You might want to try holding the top button and the home button until it turns on, then let go of the top button. Keep the home button held down until the "Plug Into iTunes" picture comes up. You should be able to normal restore now. If this doesn't work, just go get it repaired.
Oct 16, 2009 | Apple iPod touch
LOW VOLUME TO HIGH VOLUME
Is this for a specific ringtone or all ringtones on the phones?
Certain versions of the iPhone firmware have an issue where the volume keeps decreasing. Try this to fix -
1. Press the sleep button on top of the phone
2. Now press the home or sleep button so you see the "lock screen (the screen with the wallpaper that has the unlock slider)
3. Double click the home button and the ipod controls should come up on the screen.
4. The volume is probably set at the half way mark...set the volume to full.
See this fixes your problem?
Apr 13, 2009 | Apple iPhone 3G Black Smartphone
Iphone volume keeps appearing
have you tried restoring the phone or turning it off and back on?
Mar 29, 2009 | Apple iPhone 3G
Touch screen inoperative, buttons work
Hello
I have the same problems on my iTouch as well, here is what i do:
  • Restart the app
  • Reinstall it
  • Search for a newer version
Make sure u have the latest ipod touch firmware ;)
Feb 12, 2009 | Apple iPhone Smartphone
My Iphone's screen won't turn on but still vibrates
I had the same problem just now with my iPhone 3G. It froze for like an hour and a half! I heard calls come in but wasn't able to answer because the screen wouldnt come up. I pressed the top clicker button and the main button for about 10 seconds and the apple logo came up (finallyyy). It took about another minute and then the screen came back up and prompted me for my passcode. I hope this can help you all!
Jan 02, 2009 | Apple iPhone 3G
Frozen Screen
just simply tack out the battery to turn it off
Dec 15, 2008 | Apple iPhone Smartphone
Cell Phones Logo
4,534 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
