Question about Masterbuilt ESQ30B Smoker
Won't heat My smoker also will not heat. It was new 9/07 and we have used it about a dozen times. We did not notice any problems last time. Digital readout is accurate. I removed the screws that hold the heating element in place and it looks like one of the wires is fried. Its a very small opening where the element connects to the wires and I see no way to expose the rest of the wire to replace it. It seems to me that an expensive smoker should last a lot longer than 9 months of gentle use.
  • sabeacham Aug 01, 2008
    Same identical problem. Digital readout is fine but element will not heat up. Only used 8-10 times. $250 is a lot to spend on an item that breaks after 8-10 times. And yes, the warrenty is out.
  • jbellas927 Dec 24, 2008
    I got mine for Thanksgiving 2008. I've used twice and both times it took me over 4 hours to smoke a few fillets of fish. The digital read outs look fine but I could smoke faster over a book of matches. The instruction manual is vague and that is an overstatement. There is no troubleshooting section. Good luck and riddance. A coffee table...?
I have the same smoker with the same problem. I checked the heat element with an ohm meter, it was good so just cleaned the burnt residue from the male spade connectors attached to the element with a dremel tool. Slipped two new female spade connectors over the ones on the element and soldered them with the wires attached with a 1/16' silver bearing electronics solder. Now the connections cannot become loose and burn up again. I tested everything out and then wrapped the exposed connectores with non conductive fiberglass electrical tape and covered everything with expanding foam that comes in a spray can. Easy fix for me after reading all the posts from you guys here. Good luck and go for it! All I had to buy was the foam insulation.
Gary
Corpus Christi TX
Posted on Feb 19, 2009
    Problem Solver:
  • 6 Answers
  • agl002 May 31, 2011
    The Masterbuilt model 20070407 (and similar models) wiring burns off the element connector and the connector post is sometimes all that’s left. I fixed mine permanently with a very small cable clamp; grind down one side of the cable clamp body on a grinder for clearance on the element side so it don’t touch the part of the element post which will short. If there's some connecter still left on the element post, grind it off till there's only the element post left. Clamp the cable clamp to the post and tighten it; check clearance on the element side. After that, on one side of the U bolt fasten the wire with a new eyelet and an extra nut to one of the U bolt ends. It’s fixed forever. Note: you cannot solder any part to the element post as this won't work as it will melt off from the heat from the element.
My electric digital smoker wont heat. The timer works fine and the temp sets fine, but the element will not heat up . LAst use was the same problem then it eventually came on after some jostling of the...
Hi tee1134400...
Check all your connections going to the heating element...sometimes they will get corrosion on them and cause them not to function properly.
Please take time to rate me
Sep 22, 2011 | Masterbuilt 20070106 Electric Smoker
I purchased a masterbuilt smoker in Jan/2010 Model E 20070910. First time I used it had no problem with generating smoke but ever since I can not generate smoke I've tried pellets & even Hickory...
Try this...
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Jun 17, 2010 | Masterbuilt 20070106 Electric Smoker
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
Heating Element Failure
Mike in Alaska
PSU313@yahoo.com
Apr 03, 2010 | Masterbuilt 20070106 Electric Smoker
Will not heat
You have a faulty wire or bad heating element, I will bet that it is a wire broken or burned apart. Open the unit and check the wiring from the case to the element and check if it is not severed or burned apart.
Dec 24, 2009 | Masterbuilt ESQ30B Smoker
Used the masterbuilt smoker only 5 times???
Mike in Alaska
PSU313@yahoo.com
Jun 20, 2009 | Masterbuilt 20070106 Electric Smoker
Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Jan 17, 2009 | Masterbuilt 20070106 Electric Smoker
Masterbuilt ESQ30B Smoker Logo
872 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
