Question about Sony DAV-FX900W System
Push power protector
I went on vacation for two weeks and unplugged my tv, dvd, etc. i did not unglug the rear speackers. When I got back I plugged everything in and tried to listen to the surround sound but the 'PUSH POWER PROTECTOR" flashed across DVD component. Have tried the various troubleshooting options suggested in the manual, but still no sound thru speakers (brief sound bits in beginning when turn power back on each time and then silenced each time by the "popping off" of the sound. Still have picture.) Any ideas?
davebies
  • 43 Answers
SOURCE: Power and sound turn off after 15 minutes
Is the red light blinking in the front of the tv. Counnt the blink sequence then I can give you more info.
Posted on Jan 05, 2008
  • 208 Answers
SOURCE: Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Posted on Mar 29, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
welcomejee
  • 10594 Answers
SOURCE: Sharp LC-32D44
Below picture shows Audio inputs of Sony DAV-S400 and you can hook up any one.
Go to menu of home theater system and enable surround.
Need further help, let me know please...
Posted on Oct 26, 2008
Luis2584
  • 7 Answers
SOURCE: protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Feb 05, 2015 | Emerson Televison & Video
I have a Mitsubishi projection model WS-B55 that is plugged into a surge protector. The power went off for about an hour or an hour and a half this morning, and the power light is flashing. I called...
First, to answer your last question, not all power outages and subsequent surges are created equally nor are all surge protectors. Also, after a power outage where the subsequent surge is so strong that it got past your surge protector and knocks out your TV and it's never done that before... REPLACE YOUR SURGE PROTECTOR.
However, that being said, in my experience it is unlikely that the TV is going to require a technician. Understand that the person that you spoke with in tech Support is not a technician and is reading off of a list of troubleshooting pages that are more extensive then what's in the manual. What the technician is probably not aware of is that your TV, like most home electronics, has a safety failsafe that requires the device to be separated from power completely before doing a system reset
First, after pressing the button it's supposed to flash for about a minute anyway but I'm assuming that after it's done pressing that the TV is still not firing up.
Unplug the TV, let it sit for an hour, plug it back in (to the wall, not the suspect surge protector). If the light is still flashing, press the reset button again and wait for it to stop flashing and attempt to turn it on again. If it doesn't work, unplug the TV, follow the same steps however, let it sit for 24 hours before plugging it back in. That length of time is not common but some sets do require it.
If none of this works, then I would say that it's time to call a technician.
Nov 22, 2010 | Mitsubishi WS-55819 55" Rear Projection...
My 32HLX95 won't turn on. Went on vacation, TV
Unplug,replug an hour later see what happen.Power Supply board might need to replaced.
Feb 24, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Lg 42'' plasma 720p no picture
This is not good. Was your tv unplugged or just power button off when you left for vacation. PlasmaTvs are highly susceptible to damage from power surges caused by lighting. Leave unplugged for at least five minutes then plug back in and see if this helps.
Aug 15, 2009 | LG 42PQ30 42 in. Plasma TV
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Power problem
Most likely the convergence ICs are bad. These aare large black ICs attached to a heatsink. They will be marked STK393-110 and have about 15 pins or so. Replace these and check the fuses marked F9A01- F9A06 on the same board. Replace any open fuses after the IC replacement and report your results here.
Dan
Apr 21, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No power
Unplug the tv press power on and plug it back in.
some of these units have a reset clearly marked on the back.
connect direct to wall as the surge protector may now have issue.
Jan 27, 2008 | Hitachi 60VX500 60" Rear Projection HDTV
Toshiba TZ50V51
First step is to use an ohmmeter and check all fuses including
small,soldered in kind called micro-fuses.....F850,F851,F852 etc
.................................T.
Oct 03, 2007 | Toshiba 50HX81 50" Rear Projection...
Sony DAV-FX900W System Logo
205 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
