Question about Samsung CLP 300 Laser Printer
Paper feed keeps stopping
The paper starts to feed from the tray and then stops after it goes about 3 1/2 inches. I've replaced the waste toner cartridge and rotated the rubber boot on the wheel that feed the paper. I've noticed that waste toner is now accumulating inside the printer on the right hand side or the imaging unit.
L. York
lyork@tc3net.com
  • ausger Jul 18, 2008
    all of a sudden the paper feed is not printing transparency papers
    it did before, also i have put a new black toner, cleaned the paper feed
    I get faded black ink in the middle of the page form top to bottom
    please answer me on josie_cawley@yahoo.com.au
the first thing to chage the rubber at feeding whell which u did.another if u take out the the whole cartrige container, on the big green wheel some small wheels rolling and the might get black stiket thing on in it. Try to clean that as whell. the best thing to give quick cleaning service to whole printer, which will hardly take an hour.And will definitly work. if u got any prolem let me know
Posted on Jul 16, 2008
How to remove the waste toner full
first open the paper tray located at the front of the machine (where you load the paper). carefully open the adjacent smaller door to the left of the paper feed. theres the waste toner! slowly remove keeping it horizontal and empty! replace and off you go.
Sep 15, 2010 | Office Equipment & Supplies
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Paper won't feed through. goes about 2-4 inches the stops no matter how many times i clear the jam.
Hi If you remove the toner/drum unit and look into the back of the printer you will see the paper feed roller and just above it a long thin foam covered roller. Clean this foam covered roller with a damp cloth, it will be covered in toner and too slippy to feed the paper. Turn it and clean until it feels sticky again, all should now work !
Aug 31, 2010 | Samsung ML-2240 Laser Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Samsung ML2010 Printer does not receive the Paper
Make sure you have put enough paper in paper tray. Printer will not pull paper if not enough. (more than 10 sheets) hope it works. : )
Aug 10, 2009 | Samsung ML 2010 Laser Printer
Refusing to take paper
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Feb 17, 2009 | Samsung CLP 300 Laser Printer
Xerox 6110 MFP not picking paper from tray or manual feeder
sounds like you need the pickup roller & separation pad replaced
Jan 16, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
Paper keeps jamming
I was told by the local repair shop that Samsung made at least two mistakes on this printer related to the feed roller. 1) Many were installed backwards; reversing fixes it. 2) Many rollers were not manufactured correctly - replacement is about $20 (plus labor). They told me to call Samsung and ask them to at least cover labor to determine which problem; will do shortly. Don't forget, if you registered your printer, you got an extra 3 months warranty, 15 months total. I missed that by a month :(
Jun 21, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
