Question about Frigidaire CWS3600AS Top Load Washer
So I guess ts harder than it sounds to take all these peices out. I cant get to the hose even tho I unscewed the back and took off the top part of the washer. Thank you for your quick reply, but I guess Ill have to call someone, and be annoyed if indeed it is just a sock!
  • 148 Answers
I know it sucks but at least the repairman can give you a break on the cost cause you have it apart and he charges by the hour,tell him youll put back together yourself after he gets it out
Posted on Jul 13, 2008
Cold water trickling into washer - what would cause this?
Jun 18, 2014 | Frigidaire CWS3600AS Top Load Washer
Frigidaire Top Load Washer Won't Agitate FWS645GFS1
i guess you may be right
or maybe the motor
is not rotating with the ussuall speed pls inspect it..............
and ask for a technician .......
Sep 15, 2008 | Frigidaire CWS3600AS Top Load Washer
Usually when this occurs the lid switch has failed, even though it may seem ok
The lid switch is a safety device for the spin cycle. When it breaks the washer will
still agitate and not spin out. Hope this helps.
Jun 26, 2011 | Frigidaire CWS3600AS Top Load Washer
How do you access the water pump on the frigidaire crown cws3600as washer?
You pop the spring clips and raise the top then remove the front. I have your repair manual: HERE
Jan 13, 2010 | Frigidaire CWS3600AS Top Load Washer
I have a Frigidaire Crown Front loader washer, model number CWS3600AS1. The washer is not draining during spin cycle. I suspect the filter, but am not sure how to locate and replace this part.
The problem is probably the pump being clogged with an object. Typically it is a coin.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Jun 16, 2009 | Frigidaire CWS3600AS Top Load Washer
Washer will not drain on spin
We ended up opening up the washer and checking the pump and guess what , there was a tiny drill bit stuck in it that stopped it from spinning and working. Thank god we didnt burn out the pump.
Nov 11, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire washing machine top load. troubleshoot
There are levelers at the corners of the unit for levelng - tubs have springs attached to them for righting the tub while working (spinning, agitating) - also if the clothes are evenly distrbuted in tub it will wobble badly during operation.
Leaking is usually from the drain pump especially from the point whwere the hose is attached to the pump
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Cold water
Replace the water valve .Make sure you dont have a clogged screen in the valve after you remove the hoses. Please rate this !!
Aug 15, 2008 | Frigidaire CWS3600AS Top Load Washer
No hot water
Replace the valve if you have no hot water at all.
Please Rate This !
Jul 13, 2008 | Frigidaire CWS3600AS Top Load Washer
Fidgidair cws3600as1 washer leak
if you took them off then you have to reinstall a new set top seal with smooth side down
Apr 23, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
78 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
