Hi, I hope you can help me with this problem because I don't get it. The fistr faulty was a convergence problem, I replaced the three STK391-020 but when I tried to turn on the set then this problem came up, the set start up for a few seconds but then it shuts down, please if any one can help me with this.
Thanks
Hi mopacdave,
If the symptom didn't cure by convergence
adjustment through the remote control, this is an
indication of faulty convergence board inside. You may replace
the convergence IC's STK series and some of the resistors around because its already gone bad.If these parts replaced with new one, your unit will back to normal again. Also, consider bad solder joints in that area,
it will do the same symptom like what you've encountered right now. Find it first
and re-solder. If you
don't have necessary tools and
test instrument and can't do
the job yourself, I would advise you to look for a qualified technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
