Question about Pioneer Audio Players & Recorders
Hello I have a Pioneer XC-L11 cd player It no longer plays or reads cds - the display just says that there is no cd in the machine Any ideas?
  • bourboncream Jul 16, 2008
    Thanks for the advice
    The lens cleaning seemed to work at first (a cd actually played for the first time in ages!) but the system still struggles to read cds
    I think i'll take it to a shop for an estimate
    Cheers
    President:
  • 624 Answers
It is most likely that the laser pick up is bad. That is the part that reads the disc and is the most common reason. You can try a lens cleaning disc to see if it just needs to be cleaned, but if that does not work you will need to take it in for service. This problem can be caused by several different things, from the spindle motor (spins the disc), to the pick up (reads the disc), or even an IC that controls one of those things. Once you have cleaned the lens, you can also try cleaning the disc's. If a disc has a fingerprint or scratch in the area of the disc that is know as the TOC (table of contents), it will not read the disc. Fingerprints in other areas of the disc will cause the player to skip or even stop playing. I use windex and a soft cloth like a bath towel to clean the disc's, it works as good or better than the disc cleaning kits you can purchase, and it is much cheaper.
If none of this helps, it has a problem that only a trained technician can figure out with the proper test equipment. Then you must decide if it is worth getting fixed. Some service centers offer free estimates, but those are the ones that don't actually check your equipment first before giving an estimate. They just give you a ballpark figure that is usually pretty high. To get an acurate estimate you normally have to pay for it. A technicians time is worth money, my shop charges $25 for an estimate.That is pretty cheap. Some are as high as $65 for an estimate. But if you are paying for an estimate, they will normally at least troubleshoot the unit and determain just what the problem is, compared to a free estimate which is just a guess and a ballpark figure usually high to cover the cost no matter what the problem is. You may also end up paying much more for a repair when you get a free estimate, because you have already approved that amount, and many shops will charge you that much even if they find a simple problem that only takes 30 minutes to fix.
Replacing a pick up normally cost about $125 to $150 because the part can sometimes cost as much as $75.
I hope this was helpful for you and lets you make an informed decision. let me know if you need any more help.
Dave
Posted on Jul 13, 2008
  • Dave DeGain
    Dave DeGain Jul 16, 2008
    If the lens cleaning disc helped, a professional cleaning just might do the trick. The cleaning disc doesn't clean it that well. Let me know if you would like to try that and I will guide you thru it.
    Dave
I need to connect a pioneer amp m-L11 to a pioneer cd player xc L11 - which leads do I need?
It is verry simple to do (Karen) All you need is a (Audio) Patch cord, To connect it up to your amp.
Nov 05, 2012 | Pioneer Audio Players & Recorders
Need cd fixed as not playing
if the head has been cleaned properly and it wont read then its either blown its laser or the laser needs turning up
May 07, 2012 | Aiwa XC-35M 5-Disc CD Changer
Pioneer PD-M551 cd changer won't play cds 2 thru 6.
Thank you, Mark Z! My Pioneer PD-M551 would just stop reading the CD, usually near the end of the 4th or 5th disk, and then sometimes it wouldn't read any disks or maybe only the first one or two. I observed that the white ribbon cable was most contorted near near the end of the 4th through 6th disk (also discovered the disks are read proceeding from the center outward, unlike vinyl records). I unfolded the ribbon, massaged it and left it loose and unfolded and that fixed it (at least, temporarily). The PNP-1343 ribbon cable from Pioneer costs $11 but with shipping and handling it is over $30 so I haven't bought it yet.
Jan 28, 2012 | Pioneer Audio Players & Recorders
Says no game inserted,ds download play works
The problem with your ps3 player is that the lens of your ps3 is either the lens is dirty or probably the lens is very weak to read your cds.
I suggest you get a lens cleaner to clean the lens of your player, if after cleaning the lens of your ps3 player and it does not still read your cd, i suggest you replace the lens because it means the lens can no longer read cds any longer.
Take care.
Apr 30, 2010 | Nintendo DS Lite
Struggling to read new copied cds since new pc
Getting a bit old, perhaps time for a new laser unit. Unsure of price, may be better to buy a new player. get a quote.
Best of luck!
Jan 14, 2010 | Pioneer CDJ-1000 CD Player
Pioneer DEH-10 won't play cds
the cuircuit board on the cd drive is bad faulty. this is why the lens wont and can't read the info on the cd
Jul 07, 2009 | Pioneer DEH-1100 CD Player
I own an Pioneer CD tuner XC-L11 with a stereo power amplifier M-L11. Recently it won't switch on with the standby button flashing red. Nothing happens after that and the system doesn't work. Could you...
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Aug 28, 2008 | Pioneer Audio Players & Recorders
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
632 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
