Question about Nintendo Wii Console
Upgrade Problem I inserted a new game disc & It said I need to upgrade the System before play the game. I checked OK & upgrading was in progress. However, the electric plug was pulled out accidentally before it finish the upgrade!! I didn't try to power it on again since I think it's too risky before I know what situation I am facing? Any idea what will happen?
    Problem Solver:
  • 18 Answers
Hi cornet913,
It depends on what stage of the upgrade the Wii was at. If it was not near the end then you should be fine. There is part of the process where the Wii clears out the old firmware and replaces it with the new firmware, called flashing. If the Wii was switch off while flashing you might have caused serrious damage to the firmware, which can kill the console.
The only way to know is to try and switch the console back on. So give it a go, in effect if there has been any damage, then it's already done, turning the console on won't make it any worse.
If it doesn't work, call ninetendo, they might be able to repair it for you.
Posted on Jul 20, 2008
Xbox says "upgrade needed not
xbox has a new disc to go with the kinect it with upgrade your system for new games.
Mar 28, 2011 | Video Game Consoles & Games
How can u fix error 80010516?
To solve this error :
Never eject disc while game is in use.
Delete all your messages.
If playing a game on disc, clean the disc off and ensure disc is inserted properly.
Upgrade your firmware to the latest version.
Under Game settings, set PS/PS2 Upscaler to Off.
Restart your Playstation 3 and try again.
If all else fails, the disc might be defective.
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
My wii won't play the new wii games.Need to know how to upgrade?It will play the older wii games.
hi there,
the best and easiest way to upgrade the firmware on your wii is to connect the wii to your internet and look for system update in the system settings and update that way. Altthough most games that need newer firmware come with the update installed on the disc, normally once you insert the disc it will tell you it need to update the system firmware in order for the game to work, so i'm not sure why this is not happening for you if your new games not playing. The only thing i can think of if it's not updating automatically is that the wii has been chipped/modded in some way, has it? If it has'nt just connect the wii to the internet you should be able to update it that way.
Hope that helps
Feb 15, 2011 | Nintendo Wii Console
I have a Philips Home Theater model HTS3051BV/F7 C and I need to change for DVD region free or for DVD region 4, but I have not get procedure for this model. Can you help me please?
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Feb 14, 2011 | Philips HTS3051B/F7 Theater System
Will not play blue ray disc
Hi
All u need to do is to visit the manufacturer website,you will see a link "download driver upgrade". Download this upgrade and store it in a flash (if your player has a usb port) or just burn it on an empty CD.
Insert the CD or flash drive into your player,the system recognizes the upgrade and automatically installs it..and you are good to go
Good luck
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
My son saved money and bought a Xbox 360 Arcade. He did not realize that he could not play his xbox games on his new system. Is there an upgrade to allow old xbox games to be played on on the xbox 360
Some game are compatible with the new xbox 360. They are called backwards compatible and you do need to flash upgrade the OS on the new xbox 360 system.
You need to go to the xbox website and go to support and download the flash update then burn it to disk and put it on the xbox to update the software. Again not all old games are compatible with the new xbox system. If your buying used games like I do make sure it says bc next to the title before buying them.
Here is the link to the upgrade
http://www.xbox.com/en-US/games/backwardscompatibility.htm
May 19, 2009 | Microsoft Xbox 360 Arcade
Playstation 3
you need to upgrade your software this can be done by using a storage media disc,using the internet connection if you have one or inserting a new game which might make the ps3 upgrade it self
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
My dead mp4
i intalled a new firmware but bacward play and dec vol dont work in this software
Nov 25, 2007 | Audio Players & Recorders
Nintendo Wii Console Logo
136 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
