Question about SanDisk Sansa e260 MP3 Player
Kashif my sansa e260 firmware is erased and could not be started when i press the power button it shows a black screen with this message LOAD MAIN IMAGE FAILED SWITCH TO RECOVERY MODE please tell me whtan i can do i am very depressed and i want a full version of sansa e260 firmware please tell me soon thanks
I had the same issue I think to switch to recovery mode you lock the keys and hold the record button as you turn on the player. The only place I know of the get the firmware is the official website.
Posted on Jul 14, 2008
My sansa e260 goes black after showing sandisk start up screen and does the same when plugged into a pc. it starts to refresh database and then the screen goes black.
Hi there
When you say the screen goes black even after disconnecting the device from computer it could be an issue with the firmware.
It might need to have updated firmware. To get the updated firmware please go www.sandisk.com.
Where you can get the latest firmware for your model.
*** Make sure when you update the firmware keep the device in MSC mode.
Here is the link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Kindly revert for further clarifications....
Feb 17, 2010 | SanDisk Sansa e260 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Kashif
Download the Sansa Recovery Tool
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jul 06, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk e260
The volume + method listed below is the recovery method - you can somtimes substitute REC for volume +:
-Tha Mp3 Doctor
May 28, 2008 | SanDisk Sansa e260 MP3 Player
Cant switch to MSC on sansa e260
Try this instead:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 21, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Aug 05, 2007 | SanDisk Sansa e260 MP3 Player
It wont turn on
I would like to offer this solution, but this solution is only meant for the "Standard" E200 players (there are 2 types of E200 players -- the Standard E200 and the "Rhapsody" players, indicated with an "r" after the E200 such as "E260r". I'm hoping you have the standard E260. Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E260, just like I do. (I love this player)
Apr 20, 2007 | SanDisk Sansa e260 MP3 Player
Snasa e260 wont load up
Hi. Your Sansa E260 might be encountering some system errors and would need a Firmware re-flash by setting it to its recovery mode. Try this: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again. I hope this helps. The E260 is a great player.
Apr 10, 2007 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260
the firmware page doesn't exist anymore! want can i do?
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
