Please can you provide a bit more info about your PC?
Make & Model Operating system Memory whether USB 1.0 or 2.0 Bios version if poss.
Thanks
Same Problem
Jul 27, 2008
-   My external Digital Research 320 G external drive just flashes. The computer does not see it. Started after a power failure. The drive was on but the computer was off. Suspect a hardware failure.-   Homam
Jul 16, 2008
-   my computer does not read my simpletech simpledrive external 320 gb hard drive what can I do? Do I need to donwload a software? if so how do I do that?
-   Guest
most of the time its the pcb which is responsible for not detection of hd in any system also one should take into account 1 cables should be good 2 powersupply should be good 3 controller card should not be faulty. 4 any primary master slave conflict should be solved. the suggestions in 1 2 3 4 are essential before testing a hard drive.
later a bootable cd or floppy drive helps to make us do a scandisk or a fdisk . if fdisk reports no hdd or fixed disks then one should be vigilant that the drive may have been lost mbr or boot recotds
I had this problem - flashing light, disk not recognised - and found it was the power supply that was at fault. It turns out that failure of LaCie transformers is very common; they will replace faulty units.
If I switch the drive on it works perfectly. But after a few hour the blue light starts flashing and...
(More)
If I switch the drive on it works perfectly. But after a few hour the blue light starts flashing and nothing works anymore. After several trials it still remains. After a few hour he blue light starts flashing again. What is wrong?
connected to mac, won't show up on screen - was there before, but now isn't - I've reconnected it...
(More)
connected to mac, won't show up on screen - was there before, but now isn't - I've reconnected it after shutting down and the icon still doesn't appear. Power supply seems fine.
I have a Mac (OS X 10.4.11) which I have connected a Maxtor 3200 L42V9WCG...I previously stored...
(More)
I have a Mac (OS X 10.4.11) which I have connected a Maxtor 3200 L42V9WCG...I previously stored files form a windows machine but I can not seem to store anything from the Mac to it...I get an error that says the folder I'm trying to store to 'can not be modified'....under info/ownership and permissions/ it says read only with no option to change it..can you help me?
