Samsung WF337AAL/XAA washer- washing mashine with noise reduction but when it spins we hear a lot of noise and the unit moves. What can we do?
  • Anonymous Dec 08, 2008
    i have a similar problem. At around 190rpm the unit starts to shake and vibrate wildly as it would do if the drum unit was unbalanced. As the unit is supposed to detect and correct this, I am at a loss.
  • Anonymous May 04, 2009
    Same problem, Our drum will not spin freely trying to turn it by hand , three service call ,several calls to Samsung. They sell it with peds , but when there is a problem, its your floor !! I moved it to the concrete garage floor,and removed the peds ,SAMETHING!!
    Don't BUY KOREAN!!
Dont buy this crapp!! and serenesense dont tell shiittt!!!
Posted on Apr 24, 2009
I have had mine for 6 months. I noticed that they must be on a flat smooth surface. If the surface is not level you will have that problem.
Posted on Dec 09, 2008
Is there a filter on Samsung washer model WF337AAL/XAA
should b were the pump connects to or up inside the hose from mech to pump
Feb 19, 2015 | Samsung Washing Machines
Samsung washing machine wf306law xaa where is debris filter?
I have a
WF306LAW/XAA Samsung, and no idea where this filter is! Any help?
Nov 13, 2013 | Washing Machines
Samsung frontload washer model wfj1254yac
This could be caused by a seized up bearing or motor. More likely tub bearing which is uite common.
Jun 05, 2012 | Washing Machines
Washing mashine jumps around during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 25, 2011 | Kenmore Washing Machines
Washing mashine make a huge noice
Washer Problems
heatman101
Dec 30, 2010 | Washing Machines
Performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Jan 06, 2009 | Washing Machines
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
