A4tech webcam freeze after using for 1 minute.Except for webcam, USB port working fine . i try to used the same webcam on another computer and it work fine.
ghjrturhurtyrty rtyrdt dtruyh dytu drutdy
Try installing the newest drivers for your camera on the computer in question with the process below. If it still does not work contact me and I will help you for free.
http://www.a4tech.com/ennew/download%20driver.asp Go to this site and enter your make and model number, on
the next page that comes up click the pc driver button. Once it pops up the download window save it to your desktop
so you have it for future use. Move it to somewhere you will be able to find it if you need it again so you do not have
to download it again! Unzip the file with winzip and run the install program and you will be up and running. If you need
more help feel free to contact me [email protected] I will help you for free,I do this for a hobby. Send me your
number and I will walk you through the whole process. Hope this gets you going, If not get in touch and I will help you
until we get it working. Thanks,
George
The issue is likely your Internet bandwidth. Try using a wired connection from your computer to your modem as opposed to a wireless one. Make sure the webcams are plugged directly into the computer and not through a hub or extension cable. Also run a speed test to make sure you have at least 256kb of upload speed.
Make sure that the matching drivers for the operating system used are installed. Check if the webcam is connected on your PC's USB port. Also, try connecting the webcam on other USB ports on your PC. The problem is either on the USB port or the webcam unit itself. Please reply if this has helped you.
Normal
0
Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall
the software program. When the program asks you to connect the
camera to the USB port, do so and it should work.
Hope this helps. Bud
Normal
0
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
your webcam might be having any irq conflict with any other device.
Right click on my computer (in winxp) then properties, click on hardware tab and see the list of hardware installed on your pc. right click on the camera software you've installed. in properties you'll notice a resource tab...see if you have any conflict message here.
If yes try reinstalling the cam.
hope it will work.
Aliraza
for best web hosting solutions visit : http://fortehosting.com
