Question about Frigidaire PLEF398AC Electric Kitchen Range
Plef398ccc burners not turning on and rechecked wiring
Long story short. First problem the front right burner stayed on. I replaced the relay board one wire at a time. Then the digital screens for the boards did not turn on. I lifted range and that is where I found the mouse electrocuted at the hot wire for the front left burner. Stoves beeps and F5 came on all the screens. Research says that clock board needs to changed. So I changed that and still the same thing. I am hoping that it is not all the burner controls that is failed. What do you think?
  • 481 Answers
my assistance has already been rejected, so i don't know if you will get this post. before buying any more parts, check to make sure you are getting a full 220v at the outlet and test each leg (110v) against the neutral and ground wires to make sure they are good too. when you get a short, like the dead mouse scenario, the breaker might trip on one side of the dual breaker, giving you a machine that seems to have power but does not function properly.
Posted on Jul 13, 2008
I have a kenmore elite range model no. 790.9911. The right front burner wont turn off. Is it the switch, burner or control board
On this model (with the glass touch controls, right?), it is usually caused by a bad, sticking relay on the relay board, located on the back side of the oven, down near the bottom. Some of these models had a safety recall... You might want to check to see if yours is one of the affected models. (The model number you gave is not complete; find the complete model # & serial # on the range itself, usually on the range frame, visible when you open the drawer or open the door.
Dec 13, 2014 | Kenmore Kitchen Ranges
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
LG lre30451S burner will not shut off. It is stuck on high and the only way to get it to go off is to flip the breaker. When I flip the breaker back on the burner goes back to high. Thanks
I had the same problem with my LG front left burnr. Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Relay is the problem. I had the same problem with my front left burner stuck on high.
After replacing relay everything works fine.
Mar 02, 2010 | LG LRE30451 Electric Kitchen Range
Frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316225039500. Hope this helps.
Nov 16, 2009 | Frigidaire PLEF398C Kitchen Range
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
230 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
