Sharp EL-501WBBL Calculator Logo
Posted on Jan 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you do a fraction on a sharp el531w - Sharp EL-501WBBL Calculator
Anonymous
Level 2:
Novelist:
  • Expert 100 Answers
  • Posted on Jan 13, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
100
Questions
0
Helped
100332
Points
237
Hi eamon at hom,
Doing fraction on the Sharp El 531W really isn't that bad. I had to use pictures because, the symbols will not transfer over to your posting for me to show you. When you select the [ON/C] this clears the calculator of previous calculations and, data so that they won't interfere with your new calculations.
Let take the first example where a mix number is being added to a improper fraction. Because I used the [a^b/c] key this makes the calculator display the answer in a mixed fraction format or, a proper fraction format. If I press the [a^b/c] key again after the answer the format will change to a decimal format. The fractional formats are displayed in a mixed number, improper or, proper fraction formats. A improper fraction is really a proper fraction number with the top number (numerator) is greater than or equal to the bottom number (denominator).
[ON/C] [3] [a^b/c] [1] [ [a^b/c] [2] [+] [4] [a^b/c] [3] [=] mixed number results. Now let's do the same calculation as a improper or, proper fraction format.
[ON/C] [7] [a^b/c] [2] [+] [2] [a^b/c] [3] [=] still a mixed number result. Even though I enter the fractions in a improper and, proper fraction formats the calculator will still display in a mixed number format. This is because the calculator first displays as a mixed number if it can. If it can't then it will display the value as a proper fraction and, never as a improper fraction. To convert from a mixed number to a improper fraction format if the calculator did not convert it to a proper fraction, I have to use [2ndF] [d/c] keys on the command line.
This show a little more complex raised power use of the [a^b/c] key.
This shows the [2ndf] [x^-1] keys being useHow do you do a fraction on a sharp el531w - oneplusgh_45.jpgractions.
When I first saw this question being asked it, was answered with just use the / command. Which that isn't really a good answer because, in math we like to use elimination. If you use the / command eventually the numbers are going to be rounded off and, your not going to be able to eliminate anything. If you have any further question on how to preform fractions with this calculator be sure to post your comment and, I'll be glad to help.
What is the key to reduce fractions ?
The EL-501 doesn't display fractions. Some of Sharp's other calculators do, but not this one.
13helpful
2answers
How to enter fractions into the sharp el-501x
The EL-501X doesn't really work with fractions. You can always enter a fraction as a quotient. For example, you can enter 1/2 as 1 / 2, but you'll get 0.5.
Manual for sharp advanced DAL EL 531X
HELP
i am 12 and my name is Geni. i bought this SHARPadvanced DAL green calculater for fractions and whole # with fractions but i cant fuger it out please help!!!!
Where is the fraction button for sharp el-738 ? thank you
The EL-738 doesn't have a fraction mode like some other Sharp calculators.
Where is the button for fractions on the Sharp EL-738 calculator?
3helpful
How do you restore the Sharp EL531W calculator to the original settings.
For the manual see link
http://sharp-world.com/contents/calculat...
The downloaded manual pages 3 and 4 states, click the "setup 03" key and it will change to normal mode.
10000/8.1=1234.5678901 (normal mode)
setup 00 setup13 1234.568 (fix mode tab=3)
setup 01 sci mode
setup 02 eng mode
setup 03 normal mode
or just click the reset switch behind the ( Sharp el531w ) calculator, data will be deleted.
How do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
Fractions on sharp el-738 calculator
The EL-738 doesn't have a fraction mode like some of Sharp's other calculators.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
