Question about Sharp Televison & Video
I recently purchased a Sharp LC-37sb24u tv. Everything works great except the usb port. I plugged in a downloaded video and pressed input but input 1 was not an option.
I think the USB port is just for software updates.
Posted on Jul 29, 2008
How do I download latest firmware onto my Sharp Aquos LC-52LE640U?
hi does your tv have usb port if so, go to the sharp website look enter the model number of your tv look for firmware for your tv download it, then load it on to a usb flash drive, thanks
shaun
Mar 16, 2017 | Sharp LC52LE640U 52 inch 120hz AQUOS LED...
Can't play video on sharp lc-32sb24u
The USB port on LC-32SB24U is only for firmware and other service updates. The TV can't understand the video file format; you will need to connect the TV to your computer as a monitor to display the videos. The manual discusses using the Service port starting on page 26. The manual is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf .
I wish that I had better news for you.
Jun 04, 2017 | Sharp LC-32SB24U 32 in. LCD TV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have the same problem. I recently purchased a Sharp LC-52D78UN TV and I am receiving nothing but Black & White pictures when connected to Direct TV cable receiver. Why and how can it be fixed. I...
I suggest you check the cable input system. It is possible that the cable unit produces S Video or B-G and the TV is set up to receive standard quality RGB.
Hope this helps
Nov 21, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp lc-37sb24u. Flashing Green Light
Backlight invertor is most likely cause of the problem, in rare occasions defective CCFL lamps could cause similar symptoms. Replace defective parts, reset lamp error counter and you good to go.
Dec 01, 2009 | Sharp Televison & Video
Sharp Aquos - switches input modes by itself, only when cold.
I believe your TV needs the latest version software upgrade. The current software may have been corrupted.
There is a USB service port on the side of your TV. You can download the software to a USB memory stick at sharpusa.com then upgrade your TV from the service port.
If any problems doing this, call 1-800-BE-SHARP and they will run through the procedure.
Mar 31, 2009 | Sharp Televison & Video
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Arrow keys
buy a remote for your sharp....
Jan 25, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
Jan 01, 2008 | One For All URC-3021 Remote Control
Televison & Video Logo
224 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
