Question about Whirlpool Kitchen Ranges
One side of the stove door handle came un-screwed. How do I separate the two pieces of the door , so I can screw the handle back on?
There are 4 screws on the underside of the door, that once unscrewed allows the front
panel to come off. Then just below the handle, there is a bar with two screws that hold it on, one on each side of the door. Unscrewing these 2 screws and taking the bar off, gives you access to screw the handle back on.
Then put it all back together in the order you dismantled it...
Posted on Jul 15, 2008
How do I fit the oven handle back on?
many have done this having never seen a De Dietrich stove /oven I can only guess that you need to separate the door halves to put the screw back in place . and I would use some LOCK TITE on it
Oct 01, 2014 | De Dietrich Ovens
Loose handle
There is a long vertical handle held to the door by two short horizontal pieces. Run your finder along the under side of the two short pieces and feel for a very small indentation under each one. Each one is a set screw with an Allen head. Insert a small Allen wrench (English not Metric -- I don't know the size, but it is probably the next to the smallest in the set) into each one and back them out (counterclockwise looking up at the screw). The big vertical handle should come off when you back the Allen screws out far enough Now look into the short pieces sticking out from the door. Inside each one is a Philips screw holding the piece to the door. Tighten those screws with a small Philips screw driver making sure that the indents on the front of pieces will align with the vertical bar when you put it back on. When the Philips screws are tight, put the vertical bar back on and tighten the Allen screws. If you have some Loc-Tite, you might use that as well.
Mar 11, 2013 | Marvel 6BAR-BD Beverage Cooler
Interior door handle right side
first you need to order a new handle and trim ring, 2 separate pieces. beige or grey are your only choices. www.tnaautoparts.com cheapest and only one i found that caries beige. i did both front doors for 25 dollars total including shipping. Remove door panel, 2 screws under round plastic caps that pry out and off, 2 screws at bottom, 2 lg screws in middle handle, 1 plastic retainer in side that prys out, 1 screw under square cap in the center of the trim ring. remove black plastic triangle shaped piece near the mirror, prys off easy. grab door panel and pull out then lift up. leave wires attached and let panel hang loose. remove screw from old door handle. remove linkage from handle and from lock. connect linkages to new handle and lock (look carefully at the old one before you remove the linkages) , install the last screw you removed to hold lock in place while you check to if everything works. when i finished mine neither door would open from the inside. i had to take pliers and slightly bend the linkage at the elbo's to shorten the travel distance. check this before you put everything back together by just putting the door panel back in place down fist then in, window down, close door, reach in and open door, if it doesn't open bend linkage and try again. when you are sure everything is ok install all screws except the one that was under the square plastic cap in the trim ring. to install trim ring look for notch on back side toward front of ring, push ring in notch end fist, back end slightly out, when the front end is in and seated push the back end straight in. install screw and push cap in. this job is not as hard as it sounds and will make sense when have the panel off and can see.
Nov 07, 2010 | 1998 Toyota Camry
Installing driver side interior door handle
pull the inner panel off by first un screwing the two screws located on the handle portion of the panel(they may have plastic hadeaway covers over the heads) then remove the window rolldown handle(if so equipped,manual window)then pull the plastic trangle from the inner of the mirror(this little tri angle keeps the trim down and secure on the door. then pull the palnel directly out there are small clasp pins in behind the panel try not to break these(but they do sell replacements at your local auto store) you will have to get ALL of these free then wiggle the panel up releasing it from the inner shell of the door and and window. you should now have a clean view of the handle. you will now need to droll out the rivit holding the handle to the inner steel of the door. pull the handle forward and it should be released from the inner steel now there clips holding the "rods" to the handles back side, they should have a little piece clipped to the rodto un clip these you need only push them off with your thumb. then replace handle with the new one, and uce a large steel screw to secure the handle when replacing back on door.
Nov 21, 2009 | 1998 GMC Sierra
The oven handle to our Maytag stove is off on the right side, How do I get inside of the door to repair the handle? There is no selection for the stoves so I just picked one.
not an easy fix but look for screws or nuts on oven door sides carefully unscrew door should come apart to get to handle to tighten or replace bolt or screw or nut
Aug 27, 2009 | Maytag MSD2756G Side by Side Refrigerator
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Handle on oven door has come off and I need to know how to get at the screw to tighten it back on.The handle is attached to the same piece that has the vent holes in it. I don't see any screws at all to...
the door willneed to be dismantled in order to resecure t he handle, dont knowexactly which model you have , but youl need to rmov eth door from the unit, andthen with it layin on the table or other flat surfaceyoull nned to remove the screws holdiongthe lower glass panle on, and form there just a matte of removing the screws allowingyou to get top trim off the no yo can tightern handle an reassemble
Mar 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My oven door shattered. i bought the glass and the outer trim. i need help installing it
This job is best done by two people, one to hold the glass in place, and the other to operate the screwdriver and position the handle and trim pieces.
The glass is held in place by the handle assembly at the top and a metal track at the bottom.  You remove the glass by removing the handle. Open the door part way until you have access to the back of the door.  The door handle is held in place by two screws on the back (the oven side).  Remove the screws, taking care to hold the handle in place.  Be sure to brace the glass, then slowly move the handle away from the door frame.  Remove the glass.  The side trim pieces will probably fall away from the door frame, although they will probably not fall all the way out.  My advice is to carefully remove them.  Be careful; they have tabs on the bottom edge that hold them in the door frame and these tabs are easily broken.  If yours are still in one piece you might just reuse them.
Remove the old glass panel and clear the bottom track of any debris.  Put the new glass panel in, beginning with the bottom track.  Set the oven handle on the top edge of the glass panel; there are tracks on the back of the handle assembly the top edge of the glass fits into.  Bring the handle toward the door frame, taking care not to let the glass panel slip out of the tracks.   The door handle has two collars that go through holes in the door frame.  Once you've got the collars through these holes, you can put the two screws back in that secure the handle to the door.
Take one of the side trim pieces.  Each trim piece has a narrow edge and a wide edge (like a capital "L"), The narrow edge faces the front and the wide edge faces the side of the door.  Each piece has a corner edge with a little tab sticking out.  These face down.  The opposite end of the trim piece has recessed edges. These slide under the edge of the door handle.  You want to insert this end first, then work your way along the length of the trim piece pushing the narrow edge between the door frame and the glass panel.
Here's the tricky part.  To get the bottom in, the best thing to do is to open (or better yet remove altogether) the drawer beneath the oven to gain access to the screws that hold the bottom track of the glass panel to the door.  Loosen the screw that holds the track in on the same side as the trim piece you're working on; the screws are on the bottom of the track about 1 inch in from the edge. Loosen the screw slightly and pull down on that edge of the trim as you push the trim piece in behind the glass.  Repeat until the trim piece tab slips through the hole for it on the track.  Tighten the screw back in place.
Repeat this process for the other trim piece. If you're patient and gentle, it shouldn't be too difficult.  I just did this myself today (2/7/09).
Good luck.
Jan 24, 2009 | Kitchen Ranges
A4 96' back window slipped down
Open the door. At the top corners of the door panel, on the sides (the faces of the door panel that mate to the car's body when the door is shut), there is a screw on each end. Remove those. Next, in the door pull handle, there is a screw inside the pull with the head facing toward the front of the car. Take that out. You'll see that the inside area of the pull handle is a separate piece. Push hard to slide that downward and expose the final screw. Take out the last screw, hidden by the pull handle after you take it off, and then lift the door panel off the door. Be careful not to yank it too hard and damage the wiring.
Aug 10, 2008 | 1996 Audi A4
Ge profile refrigerator door handle is loose
I had this problem on this model and just repaired it.... and I am no mechanic. The bottom of the handle was loose. You'll see there is a cap on the top and bottom of the handle. You need to pop the cover off of the end that is loose. For the bottom part of the handle, I used a flat head screwdriver under the most southern portion of the handle, lifted the handle of the screwdriver towards me. The cover popped with minimal effort. Tighten the screw and replace cover. Pretty, pretty, pretty easy!
Dec 22, 2007 | Refrigerators
Kitchen Ranges Logo
78 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
