posted by VJPT on Jul 13, 2008
When I turn knob it makes sound like it is starting but will never start. This applies to any position of the knob. Any help is appreciated.
1 Other User Has The Same Problem
Comment by Dazul, posted on Jul 15, 2008
The water is a lil bit left over. I checked the hoses and the eletrical and it all seems fine. When i try to turn it on it makes a sound like it will try but then it doesnt. With and without the soap lid closed. Dishwasher is totally clean.
Best Solution
posted on Jul 21, 2008
Open the service panel in the front bottom, so you can see the motor. It sounds like it is locked-up. Look at the motor and try to free up the motor impellor.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 25, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
I discovered a completely different solution, that I'm actually embarassed to mention, but here you go. After following the advice of jbjaxiis (thanks for the suggestion) and not finding the problem, I ended up looking at the electrical cord. I followed it to under my sink only to find that something was placed on top of the cord causing it to disconnect partially from electrical socket.
So, long story short.....the electrical cord wasn't fully plugged in.
So glad I didn't call anyone out to fix it only to find the problem could've been solved in a 2 seconds. :D Good Luck!
Suggest a new solution for this problem
Post a New problem for GE Nautilus 24" Built-in Dishwasher
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
GE Nautilus wont start
The dishwasher can be closed,... Answer This...
grit like residue after cycle...
The dishes are clean, but there... Answer This...
No hot water in dishwasher
help i have a ge nautilus... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
Find Parts
