Question about Kitchen Ranges
We took the oven door apart to clean the inside glass and now cannot put the door back together properly. We have a Whirlpool Gold convection oven.
  • 1 more comment
  • jkharris200 Jul 13, 2008
    the installation page does not describe how the door itself is put together. It only addresses taking the door off and on.
    Your diagram does not address the whirlpool "gold" oven door, which is assembled with front and rear panels screwed together and a 3- panel glass assembly between. Please provide correct diagram for this model.
    Whirlpool model is GBD307. We slid the door off the hinges then took out the screws and ended up with two pieces of glass to clean and the front and back of the door. Problem is we have a bracket...long skinny piece that we cannot remember where it goes...
    Scholar:
  • 148 Answers
Ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Posted on Jul 13, 2008
  • derek martin Jul 13, 2008
    sorry thoght you meant put the oven door back on
  • 2,071 Answers
WHAT IS WRONG WITH YOUR RANGE / STOVE / OVEN?
We took the oven door - small_13_33.jpg For a detailed Range/Stove/Oven illustration, click below.
redarrow.gif Gas Free Standing
redarrow.gif Electric Free Standing
Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
    Scholar:
  • 135 Answers
Hello sir,,
U must have a service manual with u .PL take a look at installation page
Thank u
  • Harrish Mugundhan Jul 13, 2008
    is there any specific model number?
    When u took off the oven door,,,did u unscrew the door or is thre any clip type??
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to www.repairclinic.com and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
How can i clean the glass between my oven door,i noticed streaks and it makes the oven look dirty
Whirlpool door are a bit difficult to remove from the stove. the owners manual may tell you what you need to do to remove it. Once you have it off then the door can be taken apart by removing tye screws that hold it together. This should be done on a flat surface and taking a lot of care. Remember how it comes apart and reverse the procedure when putting it back together. If you break a glass they are expensive to replace if available.
May 30, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
I'm trying to put the oven door back together and it won't fit properly. any ideas? This is a whirlpool electric range mod# RF364PXPQ.
I had mine apart to clean and could not figure out how it went back together. The side strips I thought helped hold the glass in but they dont. I then discovered the side plastic strips go back in on the flip side-inner oven side. Grrrrrrrrr...wasted half a day trying to figure this out.
Nov 20, 2010 | Whirlpool RF364 Electric Kitchen Range
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do you clean the glass window inside the door. its the outside glass but it has a stain on the oposite side of that glass.
You don't, DO NOT TAKE GLASS OUT/APART!!! The glass came sealed, and the seal is compromised. The process of removing the glass and putting it back together will make it worse. I repair kitchen equipment for a living. Either live with it, or if you choose to replace it, it is costly....
Apr 07, 2010 | Electrolux 30" Self-Cleaning Freestanding...
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
Can't put door glass back in Whirlpool RF396LXE2 range
The answer is not as hard as it seems. I just tried for 10 minutes unsuccessfully to put the glass back in the two side tracks. Well the glass actually goes in front of them, the top holds the glass in place.
Apr 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Kitchen Ranges Logo
177 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
