Question about Memorex MT2206 TV
Remote only advances by one channel.
I can't change channels with the remote; I can only advance channels by one. If I am watching channel 2 for example, I can't use the remote to change from channel 2 to channel 34. The channel will change with the first number that I press on the remote. What can I do to be able to change channels?
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Posted on Sep 02, 2008
How to program the UHF remote 153638 to link with the 106240. UHF/IR
you have to go to menu and look for the IR/UHF settings for the remote control and have it change to UHF, so that it would work for both remote!
Jan 24, 2014 | DISH Network IR Remote Control
Apex digital250A digita tv converterl
The outside antenna gets threaded onto the RF connector that says antenna in. Then either connect another RF cable to the tv and select ch 3 or 4 (switch on back of box) or use the yellow,red and white cable to the tv. If you used the three cables use the remote to select the input you used. Just advance the channels until you find the picture. If you used the RF cable, just tune to channel 3 or 4 whichever you used. Now do a channel scan with the remote that came with the converter. Once that is done you will have to use that same remote to change digital channels.
Jan 01, 2014 | Apex Digital LD4088 LCD TV
Why wont my pillow remote work on my virgin tivo box?
Oh boy. here is the problem. i have also a 106240 IR/UHF receiver/transmitter that changes the channels in the satellite box from another room so i can watch them in a second tv at channel 4. the original remote for the 106240 is broken and i bought another UHF remote #153638. So i need to program the new remote to work and link with the 106240 receiver, NOT the satellite box or the tv. Is there any expert here to enlighten us how can be done ? Very simple question :how to program the remote 153638 to link with the 106240. Thank you in advance
Dec 22, 2012 | Tivo Televison & Video
I want to program my uhf receiver/ir emitter 106240
Oct 13, 2012 | Tivo Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Hello how doi adjust the left and right balance for the left and right channel level
The only 'balance' is to adjust the channels relative to each other with the test tones.
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
EFFECT : Use these buttons to increase or decrease
the amount of effect applied in a DSP or Advanced
Theater mode. When the amount of effect is
increased in a DSP/Advanced Theater mode the
characteristics of that mode become stronger and
more noticeable. The scale ranges from 10-90 with 70
as the default setting. First turn on the DSP/
Advanced Theater you want (by pressing the DSP/
Advanced Theater button until you get the mode) and
then increase or decrease the amount of effect.
CH SEL : You may want to adjust the channels when
listening to some sound sources. Use this button to
select the channel you want to adjust.
+/- : Use these buttons to select the amount of effect
in a sound mode and to adjust the channel"
Jan 16, 2011 | Pioneer VSX-24TX Receiver
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Can't advance channels with remote
Hey Guys and Gals I have the solution to your problem. Your channel memory on the remote has been forgotten. Simply navigate through your menu on the remote and rediscover the channels and your issue should be solved. I had the same issue it just took me a little time to figure it out.
BTW if you are hooking up your TV with a direct cable connection in the back without a box, and you go to the menu and do a search for air/cable channels it will even find the channels in between the regular broadcast stations (i.e. between 2 and 3 there is 2.1. which is channel 2 HD and so on for the regular stations that broadcast HD channels). Cheers and good luck the Sharp Aquos is an awesome TV!
Regards,
Jeff the Sofa King :)
Feb 05, 2008 | Televison & Video
Memorex MT2206 TV Logo
353 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
