Running slow cause to much stuff is installed. i want to clear it back to what was installed by factory
  • 667 Answers
Hi milton - what is the make and model# of your pc and did it come with recovery cds? Thanks.
Jeff
Posted on Jul 13, 2008
  • 144 Answers
Go to control panel => Add/Remove Programs=> Then remove/uninstall the not used/not required softwares.
Check your performance settings. Select "Adjust for Best Performance"
Set the right size for Virtual Memory.
After the uninstall, run a free registry cleaner like "Eusing Registry Cleaner"
Go to msconfig & remove unneccessary startup programs.
Run Disk Cleanup & Disk defragmenter.
All of above will give your pc a good boost.
Hope this helps you my friend..
My Acer Aspire One D257-1679 Laptop Constantly Freezes. Maybe Windows 7 Drivers out of Date and is not compatable.Should I do factory Reset?. Thank you
I just fixed a laptop with windows 7 freezes
windows 7 support has ended
all you need ot do is reduce the number of programs the computer is running
C drive needs lots of free space
if you want to keep the computer ..these things help
first store what you want to keep on to usb sticks
documents ,pictures ,files ,
not on the hard drive
delete all the unwanted items off the c drive
look into the users ..remove "Temp "
go through all the programs on c drive and uninstall
as many non windows 7 and unused microsoft programs and also unwanted computer games and printer drivers
clear all the downloads
clear the memory cache
defrag the c drive
scan for virus and troguns
if using versions of office above 2000 will slow /freeze the pc
windows 7 when released was based as a 32 bit and some x64
window 10 can be uploaded only if window 7 has upgraded to stage 3 but it will be slow
stuff that is X 86 will slow windows 7
Jun 29, 2016 | Acer Aspire Computers & Internet
Extremely slow
It may be that an App that you have downloaded is causing this issue. Please uninstall if not necessary. You can also reset the tablet back to original factory settings, which will erase all of your personal data, photos, downloaded Apps, etc., but will also speed it up and stop it from freezing. Please see above for how to perform a factory data reset.
Please also download the ES Task Manager from the Google Play Store. It's free, and with the tap of a button, will close all Apps running in the background, and also clear the cache. You can run this App anytime without losing any data.
Support Troubleshooting Guide
Mar 26, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Internet slow Won't load videos Zte majesty How to do a system restore cause factory reset didn't fix it
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.
To increase your internet speed follow the tips given below:
1.clear your cookies from your browser
2.Use Updated browser.
3.Install Antivirus protection Software.
After, completing this steps, you can check our internet speed from this site ScanMySpeed.com
Dec 10, 2013 | Cell Phones
Phone is running slow
You need to take a back up of your data and then do hard rest the phone . Below is how you do it .
Menu Path Method: From the Start Screen, press the Menu button and select Settings. Select SD & phone storage. Select Factory data reset. Select Reset phone. You will be prompted again, and select Erase everything. The device will reset and restore the device to the original factory settings.
Key stroke Method Power off the device. Press and hold the Volume Down and the Power Button until you see the HTC logo, followed by white screen with text and a few menu options. Press the Volume Down button to scroll down till you highlight "Factory Reset". Press the Power button to restore your phone to factory settings and also your phone will restart.
Also try not to install more stuff on your internal memory
Thumps up if this has helped .
Aug 19, 2011 | HTC Inspire 4G Smartphone
My computer is running slow and would like to know how to fix it.
Install Ccleaner, Download from:- http://www.piriform.com/ccleaner
Than clean your pc
Install Antivirus (If not) due to viruses too your pc may run slow
Apr 25, 2011 | Computers & Internet
My laptop is yery slow, missing documents and sevral threats
FACTORY RESTORE GET IT BACK TO NEW STATE ALL SHOULD BE FINE ,ONLY BEST OPTION ,LOOK ON GOOGLE FOR UR MODEL AND COMBO KEYS FOR UR FACTORY IMAGE
Jan 08, 2011 | Computers & Internet
Hard start or no start when hot.
Your choice of words is a bit confusing. "Backfire" is used in several different ways. It could mean that it's spitting back out of the carb or popping out the exhaust. But, let's try this.
Most of time when I hear complaints like this, the engine is spitting back through the carb. This is the most common problem and it's caused by one thing, the carb is running lean.
Now, the bikes come jetted very lean from the factory so that they meet EPA emissions standards. The way I usually fix this problem is to go up one size on the slow jet. The factory slow speed jet is usually a #42, and I install a #45. I also take the slide out so I can get to the needle. I lift the needle out of the slide and install a 3mm flat washer. A 3mm flat washer (flat washer for use on a 3mm bolt or screw) is about 0.023" thick. Install it by sliding in on the needle from the long end of the needle and then put the needle back in the slide. This raises the needle by the thickness of the washer enriching the mid-range mixture just slightly. This should cure your problem.
There is one other thing that can cause this problem, a bad accellerator pump. To check this, remove the air breather cover and the air filter element so you can see into the carb. Right in front of the carb you'll see a brass nozzle standing up. With the fuel turned on and the engine "OFF", twist the throttle to the wide open postion. You should see a stream of fuel squirt into the carb. If not, you need to replace you accellerator diaphragm.
As for the connector getting hot, this is usually caused by corrosion in the connector, You need to disconnect the connector and clean up the metal contacts in both ends of this. Then, put some "bulb grease", (yeah there is such a thing used on brake light bulbs and stuff to prevent corrosion) in the connector. Silicone grease will do the same thing. If left unattended to, you're going to lose the connector.
Good Luck
Steve
Jul 29, 2010 | 2003 Harley Davidson XL 1200 C Sportster...
Robotic and slow.. when it comes, eveything begins to slowdown, even playing games, watching videos from cd... i tried everything i could, delete files, checkdisks, scan and clean registry.. still it...
Could be as simple as a overheating issue. If the computer starts to slow down after running for a few minutes the the CPU could be overheating. You will need to verify that the fan is operating. Also make sure that the underside of the laptop is clear. Make sure not to block any of the air intakes under the computer. And make sure that the side exit for the heat to go out is not blocked from lint ect. You can try using a can of compressed air to blow out the dust in the cpu and heatsink area and see if this helps. If your laptop is only 3 months old then I would not attempt anything further than that because you may void the warranty. Remember that viruses and some programs can cause the computer to slowdown. Make sure you have a good virus scanner on the computer. You should download malwarebytes free version from here http://www.malwarebytes.org/ and run a complete scan. Worst case senario if you have a virus you can use your installation discs that came with your laptop to format the drive and re-install the OS to the factory condition. Make sure to back up your important stuff before you do this. If it still slows down after the re-install then I would think that the CPU fan may have stopped working causing an overheating issue. If that is the case repairs should be covered under the factory warranty.
Jun 26, 2010 | Computers & Internet
N73 is very slow
Has it always been slow? If not, you could back up all your data (synchronize it to your computer using the software on the CD that came with it,) then perform a hard rest - this will wipe everything off your phone. You can do this through the menus. I believe the option is called "reset to factory settings" or something. You'll then need to copy all the data off the pc back onto your phone. you'll also need to reinstall any applications you installed, this could be bad if you paid for them!
Oct 27, 2009 | Nokia N73 Cellular Phone
PC laptop running slow, could be malware
have you tried windows defender? it scans items running in the background and you have the option to disable or delete from system,
Dec 26, 2008 | Acer Aspire 5050-3242 Notebook
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
