I purchased samaung 20' monitor and i cant set res 1680x1050 on vista
  • 667 Answers
Hey office909 - what is the model# of your monitor please? Thanks.
Jeff
Posted on Jul 13, 2008
  • 144 Answers
Check your monitor documentation whether it supports said resolution. May be you have to search for updated display drivers.
How do I set the resolution, screen posts a box saying for best results use 1680 x 1050@60HZ, how can I set this?
In XP goto the control panel and click display. Select the Settings tab and move the screen resolution bar to the right until it says 1680x1050.
Vista should be similar to the XP instructions.
In windows 7 goto the control panel and click display. Select Adjust Resolution from the menu to the left. Now adjust the display setting to 1680x1050.
Regards, Chris
May 13, 2011 | Philips 220SW9FB 22 inch LCD Monitor
I cannot install the driver for Viewsonic VX2235wm (XP pro) Cannot select 1680x1050 res for this monitor
Well your LCD supports 1680x1050 resolution.
You have to check the video/ graphics card of your PC, if it supports the same resolution or not. Let me know the model no. and your motherboard details for a better assistance.
Looking forward for your response
CreativeTECH
Nov 13, 2010 | ViewSonic VX2235WM Monitor
Width and height ratio
You need to set your PC video output resolution to the native resolution of this monitor, which is 1680X1050 @60Hz.
Right click on the desk top, the display properties will come up, click on setting tab, then you will see resolution setting choice.
Mar 28, 2010 | Acer AL2016W 20" LCD Monitor
The text on my screen is too stretched and unfocused
Make sure that you are running at the recommended resolution for your monitor. for example, and 20" widescreen should be at a 1680x1050 res
you may need to update your drivers and or video card to achieve a widescreen resolution.
Jul 31, 2009 | Acer Computers & Internet
1440x900 Monitor seems to think it is a 1680x1050 screen @ >19"?
Try reinstalling the video driver (Control Panel - System - Device Drivers - Video ... ) Good luck
Jun 13, 2009 | ViewSonic VA1930WM LCD Monitor
Widescreen resolution (1680x1050) doesn't work
You can look for specifications about Video cards at  Tiger.com     and Newegg.com    to name two.
Jan 30, 2009 | PC Chips M810DLU (M810DLUV75C) Motherboard
Acer x213W - setting the resolution
Sorry about the delay. I also just purchased an Acer x213w and had some trouble setting up my computer in order to achieve the optimum resolution of 1680x1050.
I'm using an HP Pavilion m7170n, so it's a bit old and thus could not support this widescreen resolution. However, my computer comes with an ATI Radeon graphics card and, upon contacting HP Support, was allowed to download ATI's "Catalyst Control Centre". After installation, these drivers added the option of selecting a screen resolution of 1680x1050 from Desktop properties.
So this is my solution to you: simply google your graphics card along with 1680x1050 driver and hopefully you'll be able to download a driver update which does the same for you as it did for me.
May 11, 2008 | Computers & Internet
Acer al2016w monitor
when you say you have it plugged into the on-board video output.. does that mean there is a graphics card installed too? used to be graphics card installed? if there is or was then its possible that there is a bois setting that tells your computer to use the existent or non-existent graphics card. either was your onboard is going to shut down. This is one theory.. but since its is turning off once you get to your desk top the more likely reason is that its software based and you either have the wrong resolution, driver, or refresh rate selected to use when windows boots. Toy around with diffrent resolutions, refresh rates, also if you have a graphics card plug it into that. your on board most certinly will not be enabled if you have a graphics card.
VGA MODE in vista:
Restart the computer and immediately start pressing the F8 key, once per second. At the selection screen, use the up/down keys to select "Enable VGA Mode", then press the "Enter" key.. If it works, it will bring up the basic VGA drivers in "normal" Windows and should allow you to install the Vista compatible drivers for your new card. After installing the new drivers, restart the computer and if it remains in VGA, you should then be able to adjust the resolution, etc. from the "Display Properties".
Jan 22, 2008 | Acer AL2016W 20" LCD Monitor
Problem with the P5VDC-MX to display 1680x1050 resolution
If you go to the FAQ section for your board you will see that the screen resolution can only go to 1600x1200 UXGA, UXGA+ res name pixal depth 8/16/32
http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P5VDC-MX
FAQ page 4
Dec 30, 2007 | ASUS P5VDC-MX Motherboard
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
