Question about Sony CDX-F5510 CD Player
Bus audio In/AuxIn
When I hook up my portable MP3 player to this unit it will only play on the front speakers and not front and rear. Checked balance and fade and continues to only play on the front two speakers. Using same wires I use from same use on other stereo auxillaries.
4 Suggested Answers
  • 5 Answers
SOURCE: sony cdx mp40 bus audio in
ok dont know if you will check up on this but fm transmitters are all garbage. for true undistorted sound go to an electronics store and ask for a rca to headphone cable. then just hook it up to the rca input and run the cable out of either the unit or somewhere on the dash. this will alow for a true connection and if you buy a brand name cable i.e. monster, radioshack, sony etc. should sound amazing. always happy to help.
big c
Posted on May 23, 2008
SOURCE: Cannot play my portable audio device with Sony cdx c500x
The multichanger has to be connected,with a cd in, but then the head unit will play whatever is fed to the bus in sockets. This effectively means the multichanger is playing to itself. If you want both to work, use a pair of piggy back rca leads into the head unit, one to the cd, one to the mp3. Then break into the cd leads and feed one of the pairs, one +ve, one -ve to a double pole switch so that you cut the sound from the cd allowing the mp3 in. To play cd's, flick the switch.
Posted on Jul 27, 2008
  • 87 Answers
SOURCE: Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Posted on Jun 03, 2009
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Cant get the speakers balance its all on the right side.
ok maybe i am not understanding what you are trying to do .if you are looking for balance you found it balance is front to back and side to side. if you are saying the volume wont change you might have one rear hooked up to the front and one to the back. this is most common on cars thatare hard wired "no harness"double check the way you ran the wires good luck
Aug 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Adjusting front and speakers
Push the menu/sel button, select bal/fad. Pioneers use the same adjustment for balance and fade. push side to side for balance, up and down for adjusting front to rear
Aug 18, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Mp3 player only plays on right side speakers
Have you tried a different jack? It could be faulty.
Aug 11, 2007 | Pioneer DEH-P6800MP CD Player
Rear speakers dont play with connection box
I believe this is a wiring incompatibility problem. The reason I say this is because when the mp3 player is out the jack which contains switches engages the front L&R and the Rear L&R, when the plug is inserted into the jack the jack switches should remove the audio input to the amplifier and replace it with the audio from the mp3 player. The switches should then send sound to the front L&R and the Rear L&R but the only change should be that the mp3 player is switched in instead of the audio from the raido unit. what is happening is that the jack switches are only switching in the front L&R speakers. This just might be a function of the unit. check the owners manual. here is a site that has the manual: http://www.docs.sony.com/release/XAV7W.PDF
Sep 21, 2006 | Sony XAV-7W 7 in. Car Monitor
Sony CDX-F5510 CD Player Logo
102 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
