Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Incoming call only gets one ring
When there's an incoming call, the phone only rings once. I tried calling from my cell phone and after it rings once, there's static and my cell phone says "call suspended by network".
  • Anonymous Nov 20, 2008
    great to know what's wrong
  • Anonymous Mar 10, 2009
    incoming call only gets one ring. it was ok for about a month then the problem started. My cordless phone is Vtech 6GHz w/ Digital Answering System & 4 Handsets
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
  • 5 Answers
This question was posted on the troubleshooting page for the VT-9118. This answer is specific to this model.
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from
Posted on Apr 19, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
  • 1952 Answers
SOURCE: on incoming call,rings once then disconnects
reset the ring setting
Posted on Jul 01, 2009
  • 2460 Answers
SOURCE: Incoming calls on home phone ring 1 time and then extreme static
When you unplug everything connected to the phone jack what happens? If it works, you have too many ringers or a short on the line. If it still trips the ring, you have a defective box.
Posted on Jul 06, 2009
Nokia 6085 drops incoming calls
in profile management under caller settings you should find an option there to set the number of rings before timing out. Set it to whatever your preference is and it should solve your problem. otherwise it may be a provider issue, try calling AT&T and explaining what's going on.
Dec 02, 2013 | Nokia Cell Phones
Already have unplugged everything twice and still will not accept incoming calls. The phone rings once and cuts off. Sometimes the single ring is heard only on the outgoing phone not on the incoming call...
Try reset the phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 22, 2011 | Cell Phones
My income calls is ringing only one time how i make more this nokia e63
Go to settings- profiles- normal- activate, then get back and edit the profile, in ring style set ringing, you should have at the moment ringing once.
May 14, 2011 | Nokia E63 Cell Phone
Incoming calls only rings once
In the profile setting along with the ringtones and volume setting there should be a setting for ring option - this is prob set to 'ring once ' as apose to ring or decending...
Oct 08, 2010 | Cell Phones
Will not ring for incoming call only viberates
You should try to put it on only ring cause some phones have issues simular to yours.
Jan 31, 2010 | Motorola Mobility Adventure v750 Cell...
Sony Ericsson z750a incoming rings end too quickly.
cancell all call diverts. it may be happening due call diverting.
Jun 04, 2009 | Sony Ericsson K750i Cellular Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
Nov 19, 2008 | Nokia 3120 Cellular Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
371 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
